lots of moisture on inside windscreen and rear window
condensation on the window usually means moisture in the car. Check the carpets, door/window rubbers etc for leaks and see if you can spot anything obvious.
Is the spare wheel on the inside on these? Had this problem in a Cavalier and the spare wheel cavity was half full of water coming in from a dodgy seal on one of light clusters
I bought a 'Air Dry Car Dehumidifier' from Halfords, sorted it for me.
Alternatively, a damp catcher, a quid at Asda.
Aldi also do refills for them think theyre arouns 1kg little sacks of the damp sucker pebble things think it was 4 sacks for £3.99
Or amazon have then in little sacks too
Also check you haven't got air recirculation on. A friend of mine complained her car was really misty all the time. I went for a drive with her, turned recirc off and happy days it slowly cleared.
Think is that just masks the problem and doesn't fix it, personally I would go for finding the cause of the damp and stopping it and that will fix the problem.
Its not always that simple. My damp / misting problem only occurs when its really cold and often wet. I leave the house and walk to the car, get rained on or get my shoes wet, etc, and get in the car with it. I then turn the heater on and some of that water evaporates, only to condense again on the inside of the windscreen when the temperature drops. Its not like that's a fault with the car...
So what 'fix' should I peruse? A new house with a garage, or move to a warmer climate perhaps? I bought a 'Air Dry Car Dehumidifier' from Halfords, sorted it for me.
Am I the only person who this seemingly never happens to?
