- 27 Apr 2009
Hi guys. Was hoping for some clarification on high SP fans...
I understand the difference in design between high airflow and SP designs.. But put simply what's a great example of a high SP radiator fan that gives you good bang for buck?
I almost went with the Corsair SP120 just now but I was put off purely by the price. Are they worth it? And if so which model do you even go for... Low noise, high pressure... LEDs are nice but are they inferior in performance terms...
Also my case doesn't have noise insulation (until I custom cut my own foam) so the quieter the better within reason.
Hoping for some guidance and recommendations so I can understand how the measurements work, and I can find one to fit to my H80 radiator.
White blades or white LED would be nice.
I've had this recommended but I'm not sure if the pressure could be improved on another fan such as this Akasa one.
Any ideas? Or just straight recommendations. It's a big world of fans out there.
Thanks
Thanks
