LG 27EA63 disable "Super Energy Saving is active"
17 Jul 2008
after a few mins of using the monitor it goes dim... I have two on my system which ever monitor I attach to the HDMI cable flashes up to say its has "Super Energy Saving is active"..
I cannot see anything in the monitors menus to disable the feature..
any ideas?
From the manual, page 19:
SUPER ENERGY SAVING
1 Press FUnC. button on the bottom of the Monitor set to display the FUnC. OSD.
2 Select sUPeR eneRGY sAVInG by pressing the ► button.
3 Enter to sUPeR eneRGY sAVInG by pressing the ▼ button.
4 Set the options by pressing the ◄ or ► or ▼ buttons.
5 Select exit to leave the OSD menu.To return to theupper menu or set other menu items, use the up arrow
( ) button.
