Phanteks Ethoo pro help on fans
30 Oct 2014
Norfolk
SO i got the case, and if im correct, the 2 white fans already included are 140MM, and I want to install atleast one 120MM quiet edition Corsair fan,but cant see any place that has the holes to screw it in?
help!
When I got my Enthoo Pro it came with a 200mm fan at the front and a 140mm exhaust at the back. There are mounting points for more fans on both the roof and floor of the case. I've got 2 x 120mm on the roof and had a 120mm (now replace by a 140mm) on the floor. I think rather than specific holes for the screws there are slots instead so you can adjust the exact positioning easier.
See my build log here for some pictures of where the fans went: -
http://forums.overclockers.co.uk/showthread.php?t=18611816
Nice build man, but I still didnt see, did you remove the 200m fan and replace it? also my PSU isnt modular so there woudn't be spacing for it if i take the metal cover off due to wires unused.
I' guess i'll have to order 140mm fans if i need a replace then
I'm not sure exactly what you mean, do you want to fit 120mm fans as intakes on the front of the case in place of the supplied 200mm? If so I've not tried removing the 200mm but according to the manual it should be possible to fit 120's there.
The space on the floor of the case would probably be a bit tight for a non modular psu yeah.
Well, the 200m fan is quite loud in my opinion, isnt it loud for you? and yeah im thinking about it, i have 2 corsair AF quiet edition fans here
Yes that fan at the back is the 140mm exhaust while the one at the front is the 200mm intake.
Yeah the 200mm fan isn't the quietest but I've now got a fan controller fitted so I run it at a lower speed that reduces the noise. I might replace it with a pair of 140mm fans at some point though.
Good idea thats id do, the noise is poopy, and how do u control the fans?
