- 30 Oct 2014
- Norfolk
Gigabyte Z87-D3HP Intel Z87 (Socket 1150) DDR3 ATX Motherboard is what i have, Will ASUS Xonar DG PCI 5.1 Audio Card fit on it?
But it might worth you getting the DGX (same card, but with PCI-E instead of PCI) instead if you think you might keep using the card, even when in the future you changing to a motherboard with no PCI slot you would still be able to keep using it.
