Kelvin can be added to but pump specs indicate it doesn't have enough power. It stops pumping at 1meter of lift and 72L/H is it's maximum flow rate. That's a whole 17 gallon per hour with no resistance. In other words if you are pumping from a bucket on the ground it won't even push water as high as our chest, and even going into a 5 gallon bucket setting along side the water it would be hard pressed to fill 3 of them in an hour.
No idea how KG is doing it. Part of it is not using similar noise levels for all coolers, but there is more going on. Usually bench testing helps balance things, but obviously there testing didn't. They don't say what the actual temperature of air going into cooler / radiator is. Instead they give the room temperature. Room temperature is rarely the same as cooler / radiator intake and the intake air temp is what we need to use to get accurate comparisons between coolers. Here are results from several tests ran by George Cella. Each time he runs tests, he runs all cooler in the comparison one after the other. So the average I've put in this chart is several different runs at different times for each cooler.
Notice H100i performance and noise level. 73c@68dBA compared to PH-TC14PE 70c@36dBA. Each 10dBA increase doubles how loud it sounds to our ears. 36dBA to 46dBA is twice as loud, 56dBA is 4 time as loud as 36dBA, and 66dBA is 8 times as loud as 36dBA. H100 is
3c warmer than PH-TC14PE and
8 times as loud. Slow the fans down to 40dBA and its 7c warmer. The only AIO that out perform to air are Swiftech H220-X and H240-X .. and then only 5c & 6c respectively, slow down the fans to less than 40dBA and it's 3c & 4c.
http://www.hitechlegion.com/reviews...loop-280mm-cpu-cooler-review?showall=&start=2
