- 2 Jan 2012
- UK.
How hard is it to overclock a 970? Max out target power, +200 core, +500 mem. Done.. Why do you believe it would be any different with the 960?
If those scores are legit, we're talking GTX770 beaters with GTX650ti power/heat figures here. As long as the price isn't too close to the GTX970 this is shaping up good.
Because if the 660 is anything to go buy Nv will gimp the max voltage so it doesn't make the next card up the ladder obsolete.
There's no guarantee it will be a monster overclocker, it's likely to have the potential but that doesn't mean they'll allow it, doesn't make sound business sense.
1ghz hd5850
Its getting pretty darn long in the tooth now though!If those scores are legit, we're talking GTX770 beaters with GTX650ti power/heat figures here. As long as the price isn't too close to the GTX970 this is shaping up good.
Theres only one 4790k in the owners thread in cpu forum, 5ghz on 1.312v which is well within 24/7 voltage limits for that chip.I don't think there's a single person on earth with a 5GHz 4960K ;P
Yep, very impressive chip. Have only seen a few like this across various forums.That's a golden chip right there. Crazy that in a few years and die shrinks time 5Ghz+ overclocking will likely be the norm![]()
Certainly hope so. Coming at a nice time too as the 650 ti boost in my second system is starting to act up. And theres no way it's getting a 780 from the main system.This will be a peach of a budget card. nVidia doing the business![]()
+1
This is looking like a very nice budget GPU, good performance very low power use. Ideal for it's tier.
I wish I lived in the same world where £200 GPUs were classed as budget gear
Yes it's budget compared with three Titans, but budget, really? It's more like mid tier as it's looking more and more likely you wont get much change (if any) from 200 notes.
Any word on the TDP?
So is the rumoured Ti version not happening now we think?
