- 28 Sep 2009
Hey guys.
I'm confused over who provides the warranty for this monitor, I've sent a couple of messages back and forth through the webnote system and I keep getting the same reply, that DGM provide the warranty, not OCUK.
Do DGM only provide the 3 year warranty with proof that it was purchased from OCUK? I've read a few posts from the staff saying it is definitely provided by OCUK and even linked to them in my webnote, but I keep getting the same reply, to contact DGM for an RMA.
The reason I bought it from OCUK was for OCUK'S warranty protection, not DGM's since I've heard some fairly negative things about their customer service. I didn't think I would have to go through them. I'm sure this played a part in others decision to buy this display from OCUK as well.
Anyway here is a transcript of what was said :
Hi.
My monitor (DGM IPS-2701WPH 27") stopped working last night and I was wondering if you guys could help me out. It was ordered on the 31st of May 2013 with a 3 year warranty so it's still covered.
I'm 100 percent sure its the monitor as I've tried another monitor with the same graphics card without a problem. The display just stopped working last night after making a faint high pitched noise. If i turn it on now there is a feint flickering dgm logo which slowly fades away, no actual display from the graphics card.
Dear ********,
I am sorry to hear of this issue, as the item is over 28 days old the warranty is dealt with via the manufacturer directly, you will need to email them on [email protected]
Regards,
James Bailey
Hi. I sent this message earlier but there seems to be a bit of confusion over who covers the warranty for DGM in this case. There are quotes at the bottom from your staff on the forums.
The warranty is definitely with OCUK in this case, it's the reason I bought the monitor from OCUK.
5UB and KillerUK on the forums cleared this up in these posts.
http://forums.overclockers.co.uk/showpost.php?p=22701813&postcount=13
http://forums.overclockers.co.uk/showpost.php?p=22579765&postcount=676
I no longer have anything that came with the monitor that might have been related to the warranty, but I'm assuming the records on your system/tied to my account are enough?
Dear ******,
This is correct, the warranty is covered by DGM, it was actually my manager that replied to you previously with the information.
If you contact them on the email address given previously they will be able to RMA the product for you.
Regards,
Matt OBrien
I don't understand...I linked to posts saying OCUK covered it and he said correct and to contact DGM.....Confusing
Would appreciate it if someone could enlighten me here.
Hi.
Dear ********,
Regards,
James Bailey
Dear ******,
Regards,
Matt OBrien
