Just thought I would share my experience with fitting the NZXT Kraken G10 to a GTX 970. I wanted to go SLI for the first time. I had a GTX 970 MSI card and sold it then bought two Galax GTX 970 with Blower cooler (http://www.galax.net/europe/970v.html)as I read that these type were better for going SLI. Not sure whether this was a good decision. I thought it was best as I intended to watercool.
First the noise. As the top card was always the hotter one the fan did tend to spin a bit noisly during gaming/benchmarking. It would go 75c to 81c depending on what I was doing. The bottom card was doing 61-65c.
When I had enough spare cash I looked into watercooling and it was coming in at £275-£300 to do maybe a bit more if I included a CPU block. Then I hit snags. Only double rad I could fit in my case was the Ice Stealth as it was thin enough. Then I found out EK and XSPC do not sell full cover blocks for these cards. So my alternative was a GPU only block and cool the VRM/RAM seperately which I didnt want with a full watercooling kit.
So I then looked at the NZXT Kraken G10 and at the prices of AIO liquid coolers. I picked up a H55 refurb for the bottom one and a NZXT Kraken X41 for the top card due to the limited places I could mount them. I also bought some RAM chips for the RAM.
I took the cooler off the first card to reveal a whacking great big VRM heatsink and also no direct RAM cooling at all. Bit surprised. Then I realised the G10's were intended for full length PCB's. Bit of a snag. So I fitted it anyway but never bothered with the 92mm fan as it wasnt really cooling anything other than pushing air round my case. So I fitted them all in and added a 120mm fan blowing directly onto both VRM Heatsinks to aid cooling.
Did some gaming and benchmark tests and the top card does 49-51c and the bottom card does 41-45c which is a great improvement. Also the X41 you can use their CAM software so not only does it give you GPU and CPU temps but it tells you the temp of the liquid going round the X41 which is pretty neat.
Anyway few pics below. Some people might think it was a bit mad but quite happy with it so far. Cost about £150
One fitted
Two fitted
One fitted
Two fitted
