Anyone used these yet, especially the PRO series?
Looking to replace my AX series with lower FPI rads and these seem to fit the bill.
Want to run my fans at lower speeds but keep temperatures the same if not better.
Its just I read on one of the comments that these have 9 FPI?
Also, from looking at the 360 Roundup by Bundslymania(sorry if I got it wrong), the ST30 performs very well at 600rpm.
I really doubt it.
Normally 9 FPI exist in 60mm thick core.
alphacool ut60 has 12 fpi i believe.
All the Alphacool rads have 9 FPI. But their tolerance limits are also not great, I've seen anywhere from 8-11 FPI and various amounts of other rad to rad differences. For example, same rad (UT60 360mm version) coolant volume was measured between 450 and 500 mL by 3 different people across 4 different samples with no two samples having the same number.
