Ive not bothered altering the speed as im not getting overheating issues.The highest ive seen the top card get to is 67c in benchmarking.In prolonged gaming its usually around 55c with the other card at around 50c.
just give it a quick test take less than a few mins... afterburner set fan speed to whatever and see if it runs constant at that speed both the cards i got kept dropping off!
i guess like so many not bothered if there's a problem...as long as i don't hear it or know about it!....
hopefully there all good for you though!
I was never covered for postage last week on the two cards I sent back. Should I have been? I got the receipts for the postage right here.
Sorry to hear of the troubles OP.
How would you know if you have a problem with your fans unless you have altered them ? or you are getting overheating issues and the fans are not altering accordingly.Obviously ive not checked because i dont have any issues !
I just tested them just for you they sit quite happily at 100% without dropping![]()
Yes if you contact them they can refund the postage if you email them the receipt I asked them this the first time I sent back my 980
Thanks mate, Will do!
None of my HOF coil whine at under 2100mhz![]()
You had any news on getting the returns covered?
Also should be sending back this week for the third 980 HOF
Not yet! Hopefully they'll get to my request Monday. Will update the thread![]()
Have been refunded![]()
I'm going for the 970 reference as its on offer. As long as its not as loud I can deal with it. If its on the same level as the Galax though it will have to go back.
