I'm not sure what's best to do now.
Do you already have the H105?
If so, just use it, you'll be fine. I used the H100i on my 3930k(4.6) and never had any issues with cooling or fan noise(stock fans that came with the unit).
I'm about to buy a i7-5960X and want to overclock it to maybe 4.2-4.3
Will a Corsair H105 73.0 CFM Liquid CPU Cooler be up to the job? If not I would welcome any suggestions. Thanks
Using a H110, it will be fine. Running an overclock of 4ghz or so while keeping things quiet will be no problem. If you want to up the fans you'll be good for 4.3-4.6Ghz depending on how good the chip is. Recommended fans to go with are the Noctua Industrial 3000 rpm fans, they really kick ass! Either get the four pin versions for motherboard PWM or get the three pin for a fan controller. Sorted.
You're buying a 5960x... Literally the most powerful and expensive chip on the planet... Why you wouldn't watercool is beyond me. Honestly.
