Asus Rampage V Extreme Intel X99
4 Mar 2014
I need to know which cpu heatsinks fit this board?
Has any one been unable to fit a heatsink?
Most importantly who has successfully fitted a heatsink?
I am asking because the space seems to be limited.
It would be greatly appreciated if you were to specify the heatsink make model please
I have tried the Cooler Master Hyper 412S worked fine with good temps
http://www.overclockers.co.uk/showproduct.php?prodid=HS-037-CM&groupid=701&catid=2330
I now use the Corsair H100i with plenty of room...
The 2011-3 or x99 chipset mobos share the cpu socket as 2011, where the cpus themmself aren't cross compatable the coolers are. If the cooler lists 2011 compatability socket then it'll work. However mind you the top slot does come quite close to the cpu socket.
Also if you've the money to get a x99 rampage, you'll be getting an AIO or custom loop, so any of those would be fine.
