** NVIDIA GEFORCE GTX 960 NOW AVAILABLE & IN STOCK!! **
OcUK Staff
17 Oct 2002
OcUK HQ
Hi there
Quite possible the new best value for money gaming graphics card is now here with complete fan shut down mode even when gaming, GTX 760 beating performance for the same money, far lower power consumption, far superior overclocking potential as well. Infact these babies when overclocked can give a GTX 770 a real good bashing.
Asus GeForce GTX 960 DirectCU2 OC Strix 2048MB GDDR5 PCI-Express Graphics Card @ £189.95 inc VAT
ASUS Strix GTX 960 is an all-new gaming graphics card packed with exclusive ASUS technologies, including DirectCU II for 30% cooler and 3X quieter than reference; 0dB fan technology for light gameplay in total silence; and Blu-ray movie playback that's free from distracting background noise.
ASUS STRIX-GTX960-DC2OC-2GD5 with factory-overclocked 1291MHz GPU boost clock and 7200MHz memory speed. And also, 1317MHz GPU boost clock in OC mode provides 12% faster gaming experience. The cards with exclusive 4+1 phase Super Alloy Power components for enhanced durability and reduced 15% power noise than reference, also bundled with GPU TWEAK + XSplit Gamecaster provides easily stream and real-time intuitive graphics tuning and monitoring. All the cards come equipped with 3x DisplayPort interface to support 4K resolution surround.
Features:-
- Voxel Global Illumination Technology (VXGI)
- NVIDIA® Super Resolution technology
- NVIDIA® GameWorks technology
- NVIDIA® GameStream technology
- NVIDIA® TXAA Technology
- NVIDIA GPU Boost 2.0
- NVIDIA PhysX® Technology
- NVIDIA FXAA Technology
- NVIDIA Adaptive Vertical Sync
- NVIDIA Surround
- Support for four concurrent displays including: Two dual-link DVI, HDMI and DisplayPort 1.2
- Microsoft DirectX 12
- NVIDIA® 3D Vision® Ready
- NVIDIA SLI® Ready Technology
- NVIDIA CUDA® technology
- PCI Express 3.0 support
- OpenGL 4.4 support
- OpenCL support
- NVIDIA SHIELD Ready
- NVIDIA G-Sync Ready
Specification:-
- GeForce GTX 960
- GPU: GeForce GTX 960
- Core Base Clock: 1253MHz
- Core Boost Clock: 1317MHz
- Memory Clock: 7200MHz
- Memory Size: 2048MB GDDR5
- Bus Type: PCI Express 3.0
- Memory Bus: 128-bit
- CUDA Cores: 1024
- DirectX 12: Yes
- DVI Port: 1x Dual-Link DVI, 3x DisplayPort & 1x HDMI
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Power: 1x 6-Pin
- 350W PSU Required
- 120W TDP
- Warranty: 3yr
Only £189.95 inc VAT.
ORDER NOW
EVGA GeForce GTX 960 Superclocked 2048MB GDDR5 PCI-Express Graphics Card (02G-P4-2962-KR) @ £169.99 inc VAT
The GeForce® GTX™ 960 delivers incredible performance, power efficiency, and cutting-edge gaming technologies that only NVIDIA Maxwell™ technology can offer.
This is the perfect upgrade to advanced gaming, letting you dominate the competition with 60% faster performance and twice the power efficiency than previous-generation cards*. Unleash its massive overclocking potential and push your performance even further. Plus, it features VXGI for realistic lighting, support for smooth, tear-free NVIDIA G-SYNC™ technology, and Dynamic Super Resolution that enables 4K-quality gaming on 1080p displays.
The GTX 960 even gives you great gaming to go with NVIDIA GameStream™ technology that lets you stream PC games to NVIDIA SHIELD™ devices. *Compared to GeForce GTX 660
Features:-
- NVIDIA Surround
- OpenCL support
Specification:-
- GeForce GTX 960
- Core Base Clock: 1216MHz
- Core Boost Clock: 1279MHz
- Memory Clock: 7010MHz
- CUDA Cores: 1024
- DirectX 12: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Power: 1x 6-Pin
- 350W PSU Required
- 120W TDP
- Dimensions: Height: 4.376in 111.15mm x Length: 6.8in 172.72mm x Width: Dual Slot
- Warranty: 3yr
Only £169.99 inc VAT.
ORDER NOW
EVGA GeForce GTX 960 SSC 2048MB GDDR5 PCI-Express Graphics Card (02G-P4-2966-KR) @ £179.99 inc VAT
Features:-
- NVIDIA Surround
- OpenCL support
Specification:-
- GeForce GTX 960
- Core Base Clock: 1279MHz
- Core Boost Clock: 1342MHz
- CUDA Cores: 1024
- DirectX 12: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Power: 1x 6-Pin
- 350W PSU Required
- 120W TDP
- Warranty: 3yr
Only £179.99 inc VAT.
ORDER NOW
EVGA GeForce GTX 960 FTW 2048MB GDDR5 PCI-Express Graphics Card (02G-P4-2968-KR) @ £199.99 inc VAT
Features:-
- NVIDIA Surround
- OpenCL support
Specification:-
- GeForce GTX 960
- Core Base Clock: 1304MHz
- Core Boost Clock: 1367MHz
- CUDA Cores: 1024
- DirectX 12: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Power: 1x 6-Pin
- 350W PSU Required
- 120W TDP
- Dimensions: Height: 4.376in 111.15mm x Length: 10.1in 256.5mm x Width: Dual Slot
- Warranty: 3yr
Only £199.99 inc VAT.
ORDER NOW
Gigabyte GeForce GTX 960 "ITX Edition" 2048MB GDDR5 PCI-Express Graphics Card @ £169.99 inc VAT
Features:
- Best GTX 960 for Entry-level Gaming
- Inexpensive choice (Internet Café / SI Customers)
- OC Edition 1165MHz/1228Mhz (ref: 1127/1178)
- 4 Phase GPU Power Design (ref: 3 Phase)
- 9% Cooler than reference under full load
- 20% Lower fan noise level under full load
Specification:-
- GeForce GTX 960
- Core Base Clock: 1165MHz
- Core Boost Clock: 1228MHz
- CUDA Cores: 1024
- DirectX 12: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Power: 1x 6-Pin
- 350W PSU Required
- 120W TDP
- Warranty: 3yr
ORDER NOW
Gigabyte GeForce GTX 960 WindForce 2048MB GDDR5 PCI-Express Graphics Card @ £179.99 inc VAT
Features:
- Best GTX 960 for 3D Gaming under load
- OC Edition 1216MHz/1279Mhz (ref: 1127/1178)
- 0dB Semi-Passive Fan (up to 60 degC)
- Windforce 2X with 90mm Unique Fan Blade
- 6 Phase GPU Power Design (ref: 3 Phase)
- 6 Port Flex-Display (ref: 4 output)
- 24% Lower fan noise level under full load
Specification:-
- GeForce GTX 960
- CUDA Cores: 1024
- DirectX 12: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Power: 1x 6-Pin
- 350W PSU Required
- 120W TDP
- Warranty: 3yr
ORDER NOW
Gigabyte GeForce GTX 960 G1 Gaming 2048MB GDDR5 PCI-Express Graphics Card @ £194.99 inc VAT
Features:
- Flagship GTX 960 for with GPU Gauntlet selected components
- SOC Edition 1241MHz/1304Mhz (ref: 1127/1178) (15% better performance than ref!!)
- 0dB Semi-Passive Fan (up to 63 degC)
- Windforce 3X 300W Cooler, with LED indicator to show when fan on/off + Backplate
- 17% Cooler than reference under full load (only 66 degC!!)
- 44% Lower fan noise level under full load (only 18.1dB!!)
Specification:-
- Backplate included!
- GeForce GTX 960
- Core Base Clock: 1241MHz
- Core Boost Clock: 1304MHz
- CUDA Cores: 1024
- DirectX 12: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Power: 2x 6-Pin
- 350W PSU Required
- 150W TDP
- Warranty: 3yr
Only £194.99 inc VAT.
ORDER NOW
KFA2 GeForce GTX 960 Reference 2048MB GDDR5 PCI-Express Graphics Card - Retail @ £161.99 inc VAT
Features:-
- NVIDIA Surround
- OpenCL support
Specification:-
- GeForce GTX 960
- Core Base Clock: 1127MHz
- Core Boost Clock: 1178MHz
- CUDA Cores: 1024
- DirectX 12: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Power: 1x 6-Pin
- 350W PSU Required
- 120W TDP
- Warranty: 2yr
Only £161.99 inc VAT.
ORDER NOW
KFA2 GeForce GTX 960 Mini OC 2048MB GDDR5 PCI-Express Graphics Card - Retail (96NPH8DND8VZ) @ £169.99 inc VAT
Features:-
- NVIDIA Surround
- OpenCL support
Specification:-
- GeForce GTX 960
- CUDA Cores: 1024
- DirectX 12: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Power: 1x 6-Pin
- 350W PSU Required
- 120W TDP
- Warranty: 2yr
ORDER NOW
KFA2 GeForce GTX 960 EX OC "Back Edition" 2048MB GDDR5 PCI-Express Graphics Card - Retail (96NPH8DVD9XX) @ £179.99 inc VAT
Features:-
- NVIDIA Surround
- OpenCL support
Specification:-
- GeForce GTX 960
- Core Base Clock: 1203MHz
- Core Boost Clock: 1266MHz
- CUDA Cores: 1024
- DirectX 12: Yes
- DVI Port: 2x Dual-Link DVI, 1x DisplayPort & 1x HDMI
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Power: 1x 8-Pin
- 350W PSU Required
- 120W TDP
- Warranty: 2yr
ORDER NOW
Inno3D GeForce GTX 960 OC 2048MB GDDR5 PCI-Express Graphics Card (N960-1DDV-E5CNX) @ £169.99 inc VAT
Features:-
- NVIDIA Surround
- OpenCL support
Specification:-
- GeForce GTX 960
- Core Base Clock: 1178MHz
- Core Boost Clock: 1241MHz
- CUDA Cores: 1024
- DirectX 12: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Power: 1x 6-Pin
- 350W PSU Required
- 120W TDP
- Warranty: 2yr
ORDER NOW
Inno3D GeForce GTX 960 iChill X3 Air Boss Ultra 2048MB GDDR5 PCI-Express Graphics Card (C960-2SDN-E5CNX) @ £179.99 inc VAT
Features:-
- NVIDIA Surround
- OpenCL support
Specification:-
- GeForce GTX 960
- Core Base Clock: 1244MHz
- Core Boost Clock: 1329MHz
- CUDA Cores: 1024
- DirectX 12: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Power: 1x 6-Pin
- 350W PSU Required
- 120W TDP
- Warranty: 3yr
ORDER NOW
MSI GeForce GTX 960 Gaming 2048MB GDDR5 PCI-Express Graphics Card - Red @ £175.99 inc VAT
Features:-
- NVIDIA Surround
- OpenCL support
Specification:-
- GeForce GTX 960
- CUDA Cores: 1024
- DirectX 12: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Power: 1x 8-Pin
- 350W PSU Required
- 120W TDP
- Dimensions: 267x139x36mm (812g)
- Warranty: 3yr
Only £175.99 inc VAT.
ORDER NOW
Palit GeForce GTX 960 "Reference" 2048MB GDDR5 PCI-Express Graphics Card (NE5X960S1041-2060F) @ £158.99 inc VAT
Features:-
- NVIDIA Surround
- OpenCL support
Specification:-
- GeForce GTX 960
- CUDA Cores: 1024
- DirectX 12: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Power: 1x 6-Pin
- 350W PSU Required
- 120W TDP
- Warranty: 2yr
Only £158.99 inc VAT.
ORDER NOW
Palit GeForce GTX 960 JetStream 2048MB GDDR5 PCI-Express Graphics Card (NE5X960H1041-2060J) @ £169.99 inc VAT
Features:-
- NVIDIA Surround
- OpenCL support
Specification:-
- GeForce GTX 960
- Core Base Clock: 1203Hz
- CUDA Cores: 1024
- DirectX 12: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Power: 1x 6-Pin
- 350W PSU Required
- 120W TDP
- Warranty: 2yr
ORDER NOW
Palit GeForce GTX 960 Super JetStream 2048MB GDDR5 PCI-Express Graphics Card (NE5X960T1041-2060J) @ £179.99 inc VAT
Features:-
- NVIDIA Surround
- OpenCL support
Specification:-
- GeForce GTX 960
- CUDA Cores: 1024
- DirectX 12: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Power: 1x 6-Pin
- 350W PSU Required
- 120W TDP
- Warranty: 2yr
ORDER NOW
I have a 960 G1 here as well to test, so shall be putting it through its paces later this afternoon and seeing how well it overclocks, maybe it could potentially rival a stock 970 if it proves to be a big clocker. Shall report back in this thread later, so keep checking back guys! Yet again a service that no other etailor provides, yet OcUK does! :)
Gibbo are all these HDMI 2.0? I need it for my new Dell Mointor to run at full spec.
Also would the Asus be the quietest?
Hi there
Just had a very quick play with the 960 G1, was boosting at 1400MHz stock and it overclocked to just shy of 1600MHz and 8400MHz memory, all on stock voltage.
Heaven 4.00 Extreme Results!
So stock performance is around GTX 670 / AMD 7950 and when overclocked they approach GTX 680/770 and AMD 7970/280X performance. :)
For the money they are great especially considering the low power and low noise.
Nvidia seem to compare it with 660, so it would seem it's a replacement for that. I guess 960/965ti could be the 700 series successor.
Because it gives them bigger numbers, it is also quicker than a 760 at everything. :)
It offers 670/760 performance out the box, once overclocked it gets close and sometimes matches 680/770 performance. :)
Thing those are worst NV cards in years... Who normal would take one over 280x ?? Maybe as physxcard for 290x lol
Gibbo what does overclocked 760 offer then:P
It is progress for the mass market who would laugh at the suggestion of spending much more than £150 on a graphics card, not to mention OEM's who don't want to be shipping low end/poorly cooled computers with 250W+ TDP cards.
Yes but none of these are sub £150 so the mass market are not the target audience. I think if they weren't 128 bit it wouldn't be so hard to swallow but it just feels like these are treading water. Going to stick to an old gpu on my new build and see what the rest of the year brings.
For now it seems the 280X remains the best sub-£200 card, the 290 is still the best price/performance card and the 970 (when overclocked) towers above them all.
However I can see these 960s as perfect for living room boxes, reviews suggest low noise levels and performance is still better than PS4 (7870/270X) levels.
