Please check my bits. £600 budget.
  • Thread starter Thread starter tnx
  • Start date Start date
Well..
Here comes the first curve ball..
NOT ordering tomorrow !!
Hopefully next week ???
:confused:
I can see what might be coming..
We'll see .:rolleyes:
Heyyyyyyyyyyy
Guess who is coming round at 4:0pm to order his bits. :cool:
So here is my final take. or very close.
YOUR BASKET
1 x Intel Core i5-4690K 3.50GHz (Devil's Canyon) Socket LGA1150 Processor - OEM £185.99
1 x Asus Maximus VII Ranger Intel Z97 (Socket 1150) DDR3 ATX Motherboard £129.95
1 x Crucial MX100 256GB SATA 2.5” 7mm SSD + 9.5mm Adapter (CT256MX100SSD1) £86.99
1 x Antec High Current Gamer M 620W "80+ Bronze" Modular Power Supply £63.95
1 x TeamGroup Vulcan RED 8GB (2x4GB) DDR3 PC3-19200C11 2400MHz Dual Channel Kit (TLRED38G2400HC11CDC01) £53.99
1 x Seagate Barracuda 1TB 7200RPM SATA 6Gb/s 64MB Cache - OEM (ST1000DM003) HDD £44.99
1 x Xigmatek Mach Midi-Tower Black £19.99
1 x Raijintek Themis Black Heatpipe CPU Cooler PWM - 120mm £19.99
1 x OcUK Value DVI-D Dual Link M - M Monitor Cable (Black) - 2 Meter (DV-202) £4.99
Total : £610.82 (includes shipping : ).
If he can stretch to £610.82 I will order this.
If not I will swap out the board for the Pro Gamer. £30 cheaper or there about.
The RAM came down in price.
I swapped out the PSU for the Antec cause I really fancy getting a modular one, the case is low on space by what the review says.
Chees.
Bits ordered.:D
Did swap out the boards which is no problem.:cool:
In the end he had to make his own account and pay on his card.:)
He's really excited.
Cheers for the help guys... ;)
Update.
WOW !
OverclockersUK. Your service is second to none !!!
From me and on behalf of the lad the bits are for, thank you very much indeed.
Ordered Wednesday evening and the bits came today.
Why go anywhere else ?
Brilliant.
I have the bits sat on my table all built up and running. I like to test the build out before fitting it into the case. The cooler fan, it has to be the quietest cooler I have ever used.
Everything is fine and dandy. XMP is enabled and the RAM is running at it's optimal speed.
Thanks to all who had input on this, especially Stulid, great help, thanks very much ;)
Just to get it in the case and install the OS.
Thanks.
:D
Sorry to hark on about this but,
just installed the OS, Win 8.1 x64.
WOW ! How fast did that install.
WOW !! How fast does it start up.
Leaves me with one question though :
Why oh why have I not got a SSD :confused:
I NEED ONE..NOW !!!!
:D
