Chaps, can I pick your brains...
I just had to drive my car into a hedge due to complete brake failure. It was either that or pile into the car in front at a junction.
Now this is probably due to driving through a ford, but the brakes were working fine on a 1 mile stretch of flat road after the ford. It was only after the road dipped steeply downhill that the brakes failed.
As to the failure, the break pedal appeared to offer no resistance at all and there was a grinding sound coming from the car. I've had a look at the road and there was no ice or gravel. Was wet but the car has two new front tyres and the rear tyres are nearly new. I had the front two replaced last weekend.
So is this normal? I thought if you tested your brakes after going through a ford and they worked that they were fine. Didn't think that you could have a delayed failure.
Anyway, front right wheel is damaged, windscreen is cracked, right front wing is scraped but not dented. The wheel took the majority of the impact.
I'm just wondering whether to involve the insurance in this. Truth be told I want to get rid of the car anyway - it's not the best example of a Yaris and FSH the dealer promised is a total lie. Lots of things don't work :/
In an ideal world the insurers would write it off, but I don't think the damage is enough for that.
It was a split second thing and I didn't think about the hand brake. Was just a sort of "****, this shouldn't be happening, **** there's an expensive car in front, **** I either hit him or ditch in the hedge... OK ditching!" kind of moment
