Silverstone FT01
9 Feb 2009
Is anyone still using this case if so have you done anything about the rubbish filter position for the top fan?
I've still got mine although I'm not using it at the moment. I always used to just unscrew the whole filter/fan assembly so that I could slide the filter out. Bit of a pain tbh. I did see this youtube video:
Looks like they cut a chunk out of the side at the top and turned the assembly around so it slides out the side.
Yeah seen that one could you possibly do me a favour if its not to much of a pain to do Jon20 could you measure the top mesh on the outside of the case. Thinking of using magnetic filter on the top.
Thanks
Apem
Thanks
Apem
Yep no problem, be a bit later though.
The mesh on the outside of the case is roughly 180 x 180mm although you would probably need to trim the corners.
Not sure if you have the case yet but if you want front usb 3.0 ports, then do a search for Silverstone G11303500. Not sure if it's still sold, quick google search would suggest you can get it from Germany.
Actually OcUK sell the I/O kit. http://www.overclockers.co.uk/showproduct.php?prodid=CM-009-SV The I/O panel looks as though it should fit. Would be worth checking before hand though.
Thanks jon.
The FT01 is still the best case ive used apart from that top filter problem I loved it gutted i got rid of it.
