- 12 Oct 2012
- London
Unsure on what port this is
We tried a Bluetooth OBD2 adapter, Works fine in my friends Yarris and flashes even when the car is switched off, When in this car nothing happens, No light no nothing even when the car is on
A Bluetooth obd adapter isn't going to do anything for your airbag fault anyway.
Is that a mk2 punto? If it is download multiecuscan (free) You can connect to airbag ecu with the obd2 port. leads are dirt cheap on ebay or you can swap wires in the plug to suit. It can also connect the abs one.
ODB2 covers numerous different communication protocols, ISO9141, KWP2000, CAN, J1850 PWM, J1850 VPW etc. Not all code readers support all these protocols.
Pin 16 should be 12v if not, check fuse as above.
Pins 4 and 5 should be earth. (the two middle ones on the wider row) check continuity with ohms meter for those two.
Engine data should be on the K line - pin 7
Airbag data should be on pin 3
I've become slightly confused from what ive been reading on some forums relating to this car, This car is the 2000 version which apparently isnt OBD2 because that was installed in 2001?
