atikmpag.sys + dxgkrnl.sys + dxgmms1.sys
10 May 2010
Hi
I've started getting this BSOD with those files listed as the culrpits each time at random times either at desktop or in game. Computer will totally freeze, then BSOD, then the screen will go black saying 'no signal'.
Obvious culprit seems to be a hardware fault with the graphics card, but those other two errors have me concerned.
I've done a clean reinstall of the card drivers and tried the atikmpag.sy expansion fix listed on google but to no avail. Temp of card is idling around 40C same as it always has and I haven't changed or altered the system, it's just suddenly started to happen.
HD Radeon 6950 2gig.
Win 7 64bit
Is my card going kaput? It's over 3 years old now and out of warranty unfortunately.
What are you full system specs?
MSI ATI Radeon HD 6950 2048MB GDDR5 PCI-Express Graphics Card
Intel Core i5-2500K 3.30GHz (Sandybridge) Socket LGA1155 ProcessoRetail
Gigabyte P67A-UD3-B3 Intel P67 Chipset (Socket 1155) DDR3 Motherboard (Sandybridge) ** B3 REVISION **
Microsoft Windows 7 Bundle - Home Premium 64 Bit
Western Digital Caviar Blue 500GB SATA 6Gb/s 16MB Cache - OEM
Zalman CNPS10X-Quiet CPU Cooler (754/939/940/AM2/AM2+/AM3/775/1155/1156/1366)
Corsair XMS3 4GB (2x2GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (CMX4GX3M2A1600C9)
Samsung SH-S222BB/BEBE 22x DVD±RW SATA ReWriter (Black) - OEM
OCZ ZS 650 Watt PSU
WD 500gig HDD
Everything is stock not overclocked in anyway.
Does it give you a particular error code when it blue screens?
