A router, which you probably have and Microsoft Security essentials on all Windows PCs. Don't really need more than that apart from a bit common sense.
The benefits they offer are more options regarding security - for example pfSense is a good firewall, quite a few work environments use it.
Although, for a home user I wouldn't have thought you'd need more than your standard router - don't broadcast the SSID, have a decent password, set up MAC Address filtering etc.
MAC address filtering as a layer of security is pointless. It's easy to spoof a MAC and when a device broadcasts a packet, it contains the MAC of the device anyway.
You're far more likely to have a security issue originating from inside your network than someone breaking in from the outside.
For home use then there's not really much needed, I do still use MAC filtering white list and WPA2 for wireless, other than that just really rely on my router for everything else.
Main thing I'd say is just make sure you're keeping software up to date.
Could potentially stick an IPS in there as I have access to the kit/software, but it's not needed (might do it sometime out of curiosity).
