***The Vapers Lounge*** 2.0
Status
Not open for further replies.
Hey guys, could someone recommend me a tank/eliquid based on my requirements?
- Recently purchased a Kanger iPow2
- Very light smoker (low nicotine content)
- A friend has a KangerTech T3D (1.8O) which I find a bit strong even at 3V (that was on a 18mg liquid with 70%/30%)
Its the nic content thats too strong for you not the tank bud. 6mg and below should do you fine on anything you decide to use
Kanger t3d will be fine for you really, it would be down to the high nicotim and high PG rating that would be giving you a harsh throat hit not the tank in this case.
My recommedations would be a 60 pg 40 vg mix at around either 3 or 6mg nicotine. The higher the nicotine the more harsh the throat hit and the higher the PG also the higher the throat hit.
The coil wont make too much difference but a 1.8ohm or 2.2 ohm will be fine to use.
I smoked a fair few roll ups a day and still found a 70-30 1.2mg liquid harsh for me, now i use a 6mg one and also a 50-50 mix but thats because i have done the journey of vaping on different mixes of liquids. I can tollerate 60-40 liquid but prefer a 5050.
Guys is the orchid v3 same as v4 but smaller? / not as tall
That's the only thing I can tell the difference between the two. And what are they like for air flow compaired to a dripper? I mean the kayfuns airflow is really right now that I'm used to and committed to drippers, but I'd also like to get a tank up and working and I like the style of the orchid the deck looks better for duals over these kayfuns iv got and the orchids air holes are aligned up with where the coils go for dual coil builds which I like the look of also
Cheers
My GVC has arrived!
Jury is still out on if it is worth the hype, tastes nice but not sure if it is "amazing" just yet.
Tastes better at 20w @ 1Ohm than at 7w @ 1Ohm currently.
Just not getting any custard just a slightly sweet vanilla, think I'll let mine steep for a bit then.
This x100. :)
Got mine today too Josh, its a different colour to what it normally is, darker. Hmmm.....
Yeah, I got mine too and it's nowhere near as good as the stuff I had before which may have been left in a cupboard for a while before I got it. Any recollection on that, V_R?
Currently have it (6mg/VG heavy) in a Lemo @1.7ohm and an MX2 @0.4ohm and yeah, it's better in the Lemo build.
I'm also suspect about the colour. Seems unnaturally dark for a three weeker IMO. Perhaps there's some heat/speed steeping technique being used, or just a bit of food colouring lol :D
This is the best bubble gum flavour I've had, the longer you leave it to steep the better it is.
http://www.ecigwizard.com/e-liquid/wizmix/lovely-bubbly.html#product-tabs
It's just like pink (original )hubba bubba or the bubble gum you had at the bottom of a screwball scramble.
Going to try the fruit salad one as that has decent reviews too.
Oh and thanks for the suggestions for Irn Bru, whoever suggested VKs Zombie Puss I did try that ages ago and thought it was awful.
Vaporshark has messaged me back, they say the maximum temperture should be 450F; therefore the wicks must be cotton.
Yeah the stuff I sent you would have been a couple of months or so old, maybe longer. Custard is like a fine wine. But it can steep too long too imo.
Haven't tried the new batch yet, not even opened it yet.
I don't think Custard's go well at sub ohms, around the 1.4 mark is my liking. :)
Anyone with a Kanger Protank 2 ? Can you tip them upside down without leaks?
Don't you fill them from the bottom? It shouldn't leak no.
Nope not a fan of the GVC, the 12mg is too much for me.
Think I'm gonna order 250ml from JustVape - try out the custard mix on there, you can select whatever ratio you want 250ml-500ml-1L.
Gonna shift the GVC I think.
I have a bottle of Spectrum Vapes Vanilla custard, 70/30 6mg, I just cant vap it, its nice on the inhale, but on the exhale I get a strong pepper taste that just ruins the whole vap, got 90ml of the stuff.
Also have a 10ml of GVC heavy VG... its nicer, but still a hint of pepper on the exhale... I am guessing its my taste buds or has anyone else experienced this with a vanilla custard juice?
I dunno tbh, but I do know that this GVC isn't at it's best yet, going from my previous couple of bottles.
I'd do as V_R says and leave it in the cupboard for at least a couple more weeks.
As it is now, the stuff I make myself is far more preferable.
Status
