** THE BEST GTX 980 DEALS IN UK & NVIDIA REFERENCE 980 IS BACK AT OcUK ONLY!! **
OcUK Staff
17 Oct 2002
OcUK HQ
Hi there
OcUK has gone all out crazy on 980 deals and we've managed to locate another yet small batch of the beautiful 980 reference card, so anyone looking to do an SLI upgrade to their current reference 980, now is perfect time! We've also got great deals on 970 series too!
Check the deals out!
kfa2 geforce gtx 980 soc gamer 4096mb gddr5 pci-express graphics card (98nqh6dnc7vz) @ £399.95 inc vat
the new nvidia geforce gtx 980/970 is powered by the next generation nvidia maxwell architecture, giving you incredible performance, unmatched power efficiency, and cutting-edge features.
maxwell is the most advanced gpu architecture ever made, designed to be the engine of next generation gaming. inspired by light, it was designed to solve some of the most complex lighting and graphics challenges in visual computing. for the first time, gaming gpu's can dynamically render indirect light using the new vxgi (voxel global illumination technology). scenes are significantly more lifelike as light interacts more realistically in the game environment.
the gtx 980 is the worlds fastest gpu and the gtx 970 offers the most advanced performance in its class. each delivers 2x the performance of previous-generation card, bringing new gaming experiences to virtual reality, and ultra resolution 4k displays.
enable the detail of 4k monitors, on a 1080p display. dsr produces smoother images by rendering a game at a high resolution, then downscaling it to the native resolution of the display using advanced filtering.
geforce gtx 980 and 970 cards support tear-free, super-fast nvidia g-sync monitor display technology including 4k. together, these technologies provide the most immersive and competitive gaming experiences possible.
features:-
- voxel global illumination technology (vxgi)
- nvidia® super resolution technology
- nvidia® gameworks technology
- nvidia® gamestream technology
- nvidia® txaa technology
- nvidia gpu boost 2.0
- nvidia physx® technology
- nvidia fxaa technology
- nvidia adaptive vertical sync
- nvidia surround
- support for four concurrent displays including: two dual-link dvi, hdmi and displayport 1.2
- microsoft directx 12
- nvidia® 3d vision® ready
- nvidia sli® ready technology
- nvidia cuda® technology
- pci express 3.0 support
- opengl 4.4 support
- opencl support
- nvidia shield ready
- nvidia g-sync ready
specification:-
- advanced ir3595 digital pwm
- multi-layer ceramic capacitors (helps reduce coil whine)
- geforce gtx 980
- gpu: geforce gtx 980 (gm204)
- process: 28nm
- core base clock: 1228mhz
- core boost clock: 1329mhz
- memory clock: 7010mhz
- memory size: 4096mb gddr5
- bus type: pci express 3.0
- memory bus: 256-bit
- cuda cores: 2048
- directx 12: yes
- dvi port: 1x dual-link dvi, 3x displayport & 1x hdmi
- displayport: yes
- hdcp: yes
- hdmi: yes
- power: 2x 8-pin
- 500w psu required
- 165w tdp
- review 1: http://www.guru3d.com/articles-pages/galax-geforce-gtx-980-soc-review,1.html
- Review 2: http://hexus.net/tech/reviews/graphics/76361-galax-geforce-gtx-980-soc/
- Warranty: 2yr
Was [£419.99] Inc. VAT
Only £399.95 inc VAT.
ORDER NOW
Asus GeForce GTX 980 DirectCU II OC Strix 4096MB GDDR5 PCI-Express Graphics Card @ £467.99 inc VAT
The new NVIDIA GeForce GTX 980/970 is powered by the next generation NVIDIA Maxwell Architecture, giving you incredible performance, unmatched power efficiency, and cutting-edge features.
Maxwell is the most advanced GPU architecture ever made, designed to be the engine of next generation gaming. Inspired by light, it was designed to solve some of the most complex lighting and graphics challenges in visual computing. For the first time, gaming GPU's can dynamically render indirect light using the new VXGI (Voxel Global Illumination technology). Scenes are significantly more lifelike as light interacts more realistically in the game environment.
The GTX 980 is the worlds fastest GPU and the GTX 970 offers the most advanced performance in its class. Each delivers 2x the performance of previous-generation card, bringing new gaming experiences to virtual reality, and ultra resolution 4k displays.
Enable the detail of 4k monitors, on a 1080P display. DSR produces smoother images by rendering a game at a high resolution, then downscaling it to the native resolution of the display using advanced filtering.
GeForce GTX 980 and 970 cards support tear-free, super-fast NVIDIA G-Sync monitor display technology including 4k. Together, these technologies provide the most immersive and competitive gaming experiences possible.
Features:-
- Voxel Global Illumination Technology (VXGI)
- NVIDIA® Super Resolution technology
- NVIDIA® GameWorks technology
- NVIDIA® GameStream technology
- NVIDIA® TXAA Technology
- NVIDIA GPU Boost 2.0
- NVIDIA PhysX® Technology
- NVIDIA FXAA Technology
- NVIDIA Adaptive Vertical Sync
- NVIDIA Surround
- Support for four concurrent displays including: Two dual-link DVI, HDMI and DisplayPort 1.2
- Microsoft DirectX 12
- NVIDIA® 3D Vision® Ready
- NVIDIA SLI® Ready Technology
- NVIDIA CUDA® technology
- PCI Express 3.0 support
- OpenGL 4.4 support
- OpenCL support
- NVIDIA SHIELD Ready
- NVIDIA G-Sync Ready
Specification:-
- GeForce GTX 980
- GPU: GeForce GTX 980 (GM204)
- Core Base Clock: 1178MHz
- Core Boost Clock: 1279MHz
- Memory Clock: 7010MHz
- Memory Size: 4096MB GDDR5
- Bus Type: PCI Express 3.0
- Memory Bus: 256-bit
- CUDA Cores: 2048
- DirectX 12: Yes
- DVI Port: 1x Dual-Link DVI, 3x DisplayPort & 1x HDMI
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Power: 2x -Pin
- 500W PSU Required
- 178W TDP
- Warranty: 3yr
Was [£479.99] Inc. VAT
Only £467.99 inc VAT.
ORDER NOW
Asus GeForce GTX 980 Poseidon Platinum 4096MB GDDR5 PCI-Express Graphics Card @ £529.99 inc VAT
Designed to provide superb performance on air or liquid, the ROG Poseidon graphics card incorporates DirectCU H2O to give you the flexibility and freedom of choice.
Liquid cooling has been a choice for many PC enthusiast as a efficient means of heat removal and increased overclocking potential of carefully selected hardware. However, custom water cooling solutions can be difficult and costly, as original cooling solutions have to be removed and fitted with waterblocks. The ROG team engineered the Poseidon with revolutionary DirectCU H2O to give you the best of air and liquid cooling- providing total flexibility whether you are looking to liquid cool now or later. Venturing into liquid cooling with the Poseidon reduces GPU temperatures by up to 27°C and enjoy ultra-stable overclocking!
DirectCU H2O is a hybrid thermal solution that combines the vapor chamber and water channel with standard G1/4- inch threaded fittings to easily accommodate existing liquid cooling equipment. With liquid, DirectCU H2O achieves up to 2 times(27°C) lower temperatures while reducing noise- up to 3X quieter.
Unique fan design extends longevity by 25% by increased dust and particle resistance while efficiently dissipates heat for optimal performance.
ROG Poseidon GTX 980 features a 10-phase Super Alloy Power along with acclaimed DIGI+VRM (voltage –regulation module). DIGI+ VRM is a digital voltage regulation that provides ample room for overclocking and performance tuning while reducing power noise by 30%. Along with Super Alloy Power specially formulated concreted chokes and harden MOSFETs to withstand greater stress and heat, Poseidon GTX 980 also uses Japanese-made black metallic solid-state capacitors for 20% better temperature endurance and 5 times longer lifespan.
ROG Poseidon GTX 980 exceeds your expectations while looking amazing. ROG LED pulsates in ROG red when the card is in use.
Features:
- DirectCU H2O: 2X cooler with water cooling. 15% Cooler with air cooling.
- DIGI+ VRM with 10-phase Super Alloy Power: deliver 30% less power noise and 2.5X greater durability.
- Japanese-made black metallic capacitors: 20% better temperature endurance and 5X longer lifetime usage.
- ROG LED light: pulsate in glorious red when the card is active.
- GPU Tweak: modify clock speeds, voltage and more via an intuitive interface.
- GPU Tweak Streaming: let you share on-screen action in real time – so others can watch live as games are played.
Specification:-
- GeForce GTX 980
- CUDA Cores: 2048
- DirectX 12: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Power: 1x 6-Pin & 1x8-Pin
- 500W PSU Required
- 178W TDP
- Warranty: 3yr
Was [£559.99] Inc. VAT
Only £529.99 inc VAT.
ORDER NOW
Asus GeForce GTX 980 Matrix Platinum 4096MB GDDR5 PCI-Express Graphics Card @ £559.99 inc VAT
The world’s record GPU frequency of 2.20GHz was set on Nvidia GeForce GTX graphics cards made by Asustek and EVGA. While it is hard to believe that the GM204 GPU can be pushed further towards 2.30GHz – 2.40GHz, the new Asus ROG Matrix Platinum GeForce GTX 980 graphics card is designed to do just that when put under extreme overclocking by the professionals such as 8 Pack.
Asustek Computer on Wednesday unveiled its new graphics card that has all chances to become one of the best graphics cards for overclocking ever produced. The Matrix GTX 980 boasts not only a powerful DirectCU II cooling system (featuring two fans and five heat-pipes) and custom design of printed-circuit board, but it features extremely sophisticated 14-phase voltage regulator module (VRM) that can do magic things for overclocking as well as some other technologies for those, who want to push the graphics card to the extremes.
The digital 14-phase VRM is based on concrete-core chokes, solid-state black metallic capacitors and hardened MOSFETs. The board features two 8-pin PCIe auxiliary power connectors that can deliver up to 300W of power to the graphics board (in addition to 75W supplied through PCIe x16 slot) and one 4-pin Molex connector for memory defroster power loop. When cooled to sub-zero temperatures during extreme overclocking, the memory defroster keeps the memory chips just above freezing, preventing cold bugs from hindering overclocking.
e Asus ROG Matrix Platinum GeForce GTX 980 4GB will be the most powerful Nvidia GM204-based graphics card in Asustek’s lineup. The graphics processor of the monster graphics adapter is rated to run at up to 1342MHz out-of-the-box, a significant increase from 1216MHz recommended by Nvidia.
The ROG Matrix Platinum GTX 980 is the fourth GeForce GTX 980 graphics card in Asus’ family. The company carries a reference GeForce GTX 980, Strix GTX 980 with DirectCU II cooler and Poseidon GTX 980 featuring a hybrid cooling solution that use similar PCBs with 10-phase VRMs as well as the new ROG Matrix Platinum GTX 980 card that sports a brand-new printed-circuit board with 14-phase VRM as well as DirectCU II cooling system.
The current 2.20GHz GPU clock-rate records were set by professional overclockers using Asus Strix GTX 980 and EVGA GeForce GTX 980 Classified ACX 2.0 graphics cards that were cooled by liquid nitrogen cooling.
The Strix GTX 980 sports custom design of printed-circuit board with 10-phase digital VRM, the same one is used by Asus Poseidon GTX 980 graphics card, which has proven to be among the best in the industry. EVGA’s GTX 980 Classified sports custom PCB with 14-phase VRM, its voltages can be controlled using a special device. It will be very interesting to see whether Asustek’s engineers have managed to create a better voltage-regulating module than developers from EVGA and whether such VRM actually enables better overclocking. Will the record of 2.20GHz/9GHz (GPU/memory) stand or fall?
Features:
- DIGI+ VRM with 14-phase Super Alloy Power: deliver 30% less power noise and 2.5X greater durability.
Specification:-
- GeForce GTX 980
- Core Base Clock: 1253MHz
- Core Boost Clock: 1342MHz
- CUDA Cores: 2048
- DirectX 12: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Power: 2x8-Pin
- 600W PSU Required
- 375W TDP
- Warranty: 3yr
Was [£599.99] Inc. VAT
Only £559.99 inc VAT.
ORDER NOW
EVGA GeForce GTX 980 Classified ACX 2.0 4096MB GDDR5 PCI-Express Graphics Card (04G-P4-3988-KR) @ £539.99 inc VAT
The new EVGA GeForce GTX 980 is powered by the next generation NVIDIA Maxwell Architecture, giving you incredible performance, unmatched power efficiency, and cutting-edge features.
Features:-
- NVIDIA Surround
- OpenCL support
Specification:-
- GeForce GTX 980
- Core Base Clock: 1291MHz
- Core Boost Clock: 1393MHz
- CUDA Cores: 2048
- DirectX 12: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Dimensions: 268.6 x 98.4 x 40 mm
- Power: 2x 8-Pin
- 600W PSU Required
- 178W TDP
- Warranty: 3yr
Only £539.99 inc VAT.
ORDER NOW
Gigabyte GeForce GTX 980 G1 Gaming 4096MB GDDR5 PCI-Express Graphics Card @ £467.99 inc VAT
GIGABYTE WINDFORCE 3X 600W cooling system once again break the record and bring the air cooling capacity up to 600W by only using 2 slots heights. The WINDFORCE 3X 600W cooling system is equipped with five 8mm and one 6mm composite cooper heat-pipes , special fin architecture, unique blade fan design, and GIGABYTE “Triangle Cool” technology. This not only provides an effective heat dissipation capacity but also enables higher performance due to a lower temperature.
GIGABYTE Flex display technology can automatically detect any connected monitors and achieve multi-display gaming up to 4 monitors at the same time by using various output groups. Users could enjoy the best gaming experience in ultra HD resolution with extended flexibility in arranging monitor configurations and making future system upgrade extremely easy.
With GPU Gauntlet™ Sorting, the Gigabyte SOC graphics card guarantees the higher overclocking capability in terms of excellent power switching. Ultra Durable VGA board provides dramatic cooling effect on lowering both GPU and memory temperature by doubling the copper inner layer of PCB. Ultra Durable VGA board reduces voltage ripples in normal and transient state, thus effectively lowers noises and ensures higher overclocking capability. Ultra Durable VGA board allows more bandwidth for electron passage and reduces circuit impedance. The less circuit impedance, the more stable flow of current and can effectively improve power efficiency.
Features:-
- WINDFORCE 3X 600W cooling system
- Flex Display Technology(patent-pending)
- Powered by NVIDIA GeForce GTX 980 GPU
- Integrated with industry's best 4GB GDDR5 memory 256-bit memory interface
- Features Dual-link DVI-I / DVI-D / HDMI / DisplayPort*3
- BASE: 1228 MHz / BOOST: 1329 MHz
- System power supply requirement: 600W(with two 8-pin external power connectors)
- NVIDIA Surround
- OpenCL support
Specification:-
- GeForce GTX 980
- Core Base Clock: 1228MHz
- Core Boost Clock: 1329MHz
- CUDA Cores: 2048
- DirectX 12: Yes
- DVI Port: 1x Dual-Link DVI, 1x DVI, 3x DisplayPort & 1x HDMI
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Dimensions: L=312mm, W=129mm, H=43mm
- Power: 2x 8-Pin
- 600W PSU Required
- 220W TDP
- Warranty: 3yr
- Bit-Tech Review: http://www.bit-tech.net/hardware/graphics/2014/10/02/gigabyte-geforce-gtx-980-g1-gaming-review/1
ORDER NOW
Inno3D GeForce GTX 980 "iChill Herculez X4 Air Boss Ultra" 4096MB GDDR5 PCI-Express Graphics Card (C98U-1SDN-M5DNX) **OcUK Exclusive** @ £449.99 inc VAT
Features:-
- NVIDIA Surround
- OpenCL support
Specification:-
- GeForce GTX 980
- Core Base Clock: 1266MHz
- Core Boost Clock: 1367MHz
- Memory Clock: 7200MHz
- CUDA Cores: 2048
- DirectX 12: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Power: 2x 6-Pin
- 500W PSU Required
- 178W TDP
- Review: http://www.kitguru.net/components/g...980-ichill-herculez-x4-air-boss-ultra-review/
Review: http://www.overclock3d.net/reviews/gpu_displays/inno3d_ichill_gtx980_review/1
- Warranty: 3yr
Was [£469.99] Inc. VAT
Only £449.99 inc VAT.
ORDER NOW
MSI GeForce GTX 980 "Reference Design" 4096MB GDDR5 PCI-Express Graphics Card @ £461.99 inc VAT
Features:-
- NVIDIA Surround
- OpenCL support
Specification:-
- GeForce GTX 980
- Core Base Clock: 1127MHz
- Core Boost Clock: 1216MHz
- CUDA Cores: 2048
- DirectX 12: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Power: 2x 6-Pin
- 500W PSU Required
- 178W TDP
- Warranty: 3yr
Only £461.99 inc VAT.
ORDER NOW
OcUK GeForce GTX 980 "Reference Design" 4096MB GDDR5 PCI-Express Graphics Card @ £439.99 inc VAT
Features:-
- NVIDIA Surround
- OpenCL support
Specification:-
- GeForce GTX 980
- CUDA Cores: 2048
- DirectX 12: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Power: 2x 6-Pin
- 500W PSU Required
- 178W TDP
- Warranty: 3yr
Only £439.99 inc VAT.
ORDER NOW
Zotac GeForce GTX 980 "Reference Design" 4096MB GDDR5 PCI-Express Graphics Card (ZT-90201-10P) @ £461.99 inc VAT
Features:-
- NVIDIA Surround
- OpenCL support
Specification:-
- GeForce GTX 980
- CUDA Cores: 2048
- DirectX 12: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Power: 2x 6-Pin
- 500W PSU Required
- 165W TDP
- Warranty: 5yr (2yr +3yr FREE when you register the product with Zotac within 28 days of purchase)
ORDER NOW
Asus GeForce GTX 970 DirectCU II OC Strix 4096MB GDDR5 PCI-Express Graphics Card @ £289.99 inc VAT
Features:-
- NVIDIA Surround
- OpenCL support
Specification:-
- GeForce GTX 970
- GPU: GeForce GTX 970 (GM204)
- Core Base Clock: 1114MHz
- Core Boost Clock: 1253MHz
- CUDA Cores: 1664
- DirectX 12: Yes
- DVI Port: 2x Dual-Link DVI, 1x DisplayPort & 1x HDMI
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Power: 1x 8-Pin
- 450W PSU Required
- 225W TDP
- Warranty: 3yr
Was [£299.99] Inc. VAT
Only £289.99 inc VAT.
ORDER NOW
KFA2 GeForce GTX 970 EX OC "Black Edition" 4096MB GDDR5 PCI-Express Graphics Card (97NQH6DNB4TX) @ £259.99 inc VAT
Features:-
- Extreme factory overclock
- Anodized aluminum backplate protects components and reinforces the PCB
- All new Silence Extreme cooler reduces temps by up to 10C
- Silence Extreme technology switches to single fan cooling at idle for almost noiseless operation
Quad mixed-gauge heat pipes ensure maximum heat dissipation
- Copper base with solid aluminum cover
- 5 + 2 Phase enhanced power system with 8 + 6-pin inputs delivers up to 50% more power for overclocking
- NVIDIA Surround
- OpenCL support
Specification:-
- GeForce GTX 970
- Core Base Clock: 1164MHz
- Core Boost Clock: 1317MHz
- CUDA Cores: 1664
- DirectX 12: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Power: 1x 8-Pin & 1x 6-Pin
- 450W PSU Required
- 150W TDP
- Review: http://www.overclock3d.net/reviews/gpu_displays/galax_gtx970_ex_oc_black_edition_review/20
- Warranty: 2yr
Was [£275.99] Inc. VAT
Only £259.99 inc VAT.
ORDER NOW
KFA2 GeForce GTX 970 OC Silent "Infinity Black Edition" 4096MB GDDR5 PCI-Express Graphics Card **WorldWide Exclusive** @ £281.99 inc VAT
Since Overclockers UK introduced our Infinity system range, demand for high performance zero compromise systems has exploded. Our Infinity brand represents performance hardware coupled with a unique and stylish aesthetic.
Since the release of high end Maxwell architecture, the hardware game has changed. The new GeForce cards offer revolutionary new technologies and class leading performance alongside low operating temperatures and impressive power consumption.
The GALAX GeForce GTX 970 OC Silent "Infinity Black Edition" is a collaboration of one of the largest Nvidia board partners worldwide, Overclockers UK Graphics Specialist: Andrew Gibson and Overclockers UK Technical Specialist & Overclocking World Champion, Ian ‘8Pack’ Parry.
Originally the Galax 970 EX OC Black Edition was intended as a high performance option for customers looking for the ultimate gaming experience with class leading performance. Our close partnership with Galax allowed us to specify a list of important modifications that would make the GALAX GeForce GTX 970 OC Silent "Infinity Black Edition" a real show stopper.
Primarily, to fit the Infinity aesthetic, we demanded that the external design of our Black Edition card was sleek and stealthy. Adding to the already imposing look of the Galax design, this new, aggressive appearance really highlights the intent behind this product.
Additionally to the colour change, we included a nickel plated I/O plate, heatsink and heatpipes to compliment the premium nature of the product. The already impressive backplate on the card has been accented with a stylish "Infinity: Inspired by 8 Pack" decal.
The imposing looks of the card would be nothing without the ‘go’ to back up all the show.
Building on the already impressive performance of the GTX 970 platform, world class overclocking expertise from 8Pack has been implemented to fine tune the BIOS of this card to achieve maximum safe, reliable performance from the GTX 970.
As an industry leading gaming and high end hardware specialist, Overclockers UK understands the importance of offering a product that meets a customer’s expectation. A major worry for any enthusiast is operational noise under load. We have used this knowledge to reduce coil whine by using higher quality components and also using glue to attach the inductors to the PCB to help reduce electrical vibrations which help reduce whine.
This collaboration with Galax has allowed us to build what we believe to be the finest example of a GTX 970 on the market today.
This product is exclusively available from Overclockers UK and Caseking group throughout UK and Europe. We suggest European customers visit www.caseking.de to purchase this card in Western Europe and Eastern European customers purchase from http://www.kellytech.hu/
Features:-
- OcUK Zero Coil Whine guarantee*
- Samsung memory guarantee
- All Black Design!
- Nickel plated I/O Plate
- Nickel plated heatsink and heatpipe
- All black shroud/cooling design
- Black PCB
- Black Backplate with Inspired by 8 Pack logo
- Inductors placed in higher quality containers and glued to PCB to reduce coil whine
- Extreme factory overclock with huge OC potential
- NVIDIA Surround
- OpenCL support
Specification:-
- GeForce GTX 970
- CUDA Cores: 1664
- DirectX 12: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- 450W PSU Required
- 150W TDP
- Dimensions: 260mm (L) x 120mm (H) x 40mm (W)
- Zero coil whine guarantee
- KitGuru Review: http://www.kitguru.net/components/g...rce-gtx-970-oc-silent-infinity-black-edition/
- Warranty: 2yr
*If your card emits any coilwhine when used on a decent power supply that is 80+ Gold rated or higher then OcUK will refund or exchange the card. These cards incorporate our exclusive Coil Whine Reduction technology to help reduce and eliminate any whine.
Was [£289.99] Inc. VAT
Only £281.99 inc VAT.
ORDER NOW
Inno3D GeForce GTX 970 OC 4096MB GDDR5 PCI-Express Graphics Card @ £251.99 inc VAT
Features:-
- NVIDIA Surround
- OpenCL support
Specification:-
- GeForce GTX 970
- Core Base Clock: 1088MHz
- Core Boost Clock: 1228MHz
- CUDA Cores: 1664
- DirectX 12: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Power: 2x 6-Pin
- 450W PSU Required
- 150W TDP
- Warranty: 2yr
Was [£265.99] Inc. VAT
Only £251.99 inc VAT.
ORDER NOW
Inno3D GeForce GTX 970 "iChill Herculez X4 Air Boss Ultra" 4096MB GDDR5 PCI-Express Graphics Card (C97U-1SDN-M5DNX) **OcUK Exclusive** @ £289.99 inc VAT
The GeForce® GTX™ 970 is a high-performance graphics card designed for serious gaming. Powered by new NVIDIA® Maxwell™ architecture, it features advanced technologies and class-leading graphics for incredible gaming experiences.
Features:-
- NVIDIA Surround
- OpenCL support
Specification:-
- GeForce GTX 970
- Core Boost Clock: 1305MHz
- CUDA Cores: 1664
- DirectX 12: Yes
- DVI Port: 1 x DVI, 3 x DP and 1 x HDM
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Power: 2x 6-Pin
- 450W PSU Required
- 150W TDP
- Warranty: 3yr
ORDER NOW
MSI GeForce GTX 970 Gaming Edition 4096MB GDDR5 PCI-Express Graphics Card @ £281.99 inc VAT
Features:-
- NVIDIA Surround
- OpenCL support
Specification:-
- GeForce GTX 970
- Core Base Clock: 1140MHz
- CUDA Cores: 1664
- DirectX 12: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- 450W PSU Required
- 150W TDP
- Warranty: 3yr
ORDER NOW
OcUK GeForce GTX 970 "NVIDIA 970 Cooler Edition" 4096MB GDDR5 PCI-Express Graphics Card @ £299.99 inc VAT
This very special NVIDIA GeForce GTX 970 is the only one of its kind designed by our in-house VGA Guru Gibbo making this the worlds ONLY genuine reference 970 available in the world. Gibbo's design request were very specific, genuine NVIDIA 970 cooler, yes the crazy expensive one just like the 980 cooler and a NVIDIA BGA Board using all original NVIDIA components with absolute zero cost down in the design.
Infact Gibbo improved the design by changing the containers in which the inductors are located for better quality items to help reduce and eliminate any possibility of coil whine. We also instruct our factory to only build these cards with Samsung memory. So why buy this over any other 970, well it is most likely the quietest whilst under load (gaming) due to having the NVIDIA cooler and any chances of coil whine have being pretty much eliminated with the design changes Gibbo has had implemented.
So this card is ideal for those seeking as little noise as possible and the other major advantage is the NVIDIA cooler which offers much better cooling performance in smaller enclosures or when running in 2-way or 3-way SLI.
Finally of course this card is perfect for when Half Life 3 is finally released at some point in the future and of course the latest GTA V game which is now confirmed!
The GTX 980 is the worlds fastest GPU and the GTX 970 offers the most advanced performance in its class. Each delivers 2x the performance of previous-generation card, bringing new gaming experiences to virtual reality, and ultra resolution 4k displays.<br /><br />
Enable the detail of 4k monitors, on a 1080P display. DSR produces smoother images by rendering a game at a high resolution, then downscaling it to the native resolution of the display using advanced filtering.<br /><br />
GeForce GTX 980 and 970 cards support tear-free, super-fast NVIDIA G-Sync monitor display technology including 4k. Together, these technologies provide the most immersive and competitive gaming experiences possible.<br /><br />
Features:-
- Voxel Global Illumination Technology (VXGI)<br />
- NVIDIA® Super Resolution technology<br />
- NVIDIA® GameWorks technology<br />
- NVIDIA® GameStream technology<br />
- NVIDIA® TXAA Technology<br />
- NVIDIA GPU Boost 2.0<br />
- NVIDIA PhysX® Technology<br />
- NVIDIA FXAA Technology<br />
- NVIDIA Adaptive Vertical Sync<br />
- NVIDIA Surround<br />
- Support for four concurrent displays including: Two dual-link DVI, HDMI and DisplayPort 1.2<br />
- Microsoft DirectX 12<br />
- NVIDIA® 3D Vision® Ready<br />
- NVIDIA SLI® Ready Technology<br />
- NVIDIA CUDA® technology<br />
- PCI Express 3.0 support<br />
- OpenGL 4.4 support<br />
- OpenCL support<br />
- NVIDIA SHIELD Ready<br />
- NVIDIA G-Sync Ready<br />
Specification:-<br />
- Genuine NVIDIA 970 Cooler with Visualizer<br />
- Genuine NVIDIA 980 PCB<br />
- Samsung memory guaranteed<br />
- Coil Whine reduction technology: We specify the capacitors/inductors to be enclosed in plastic containers as it helps reduce/eliminate coil whine<br />
- GeForce GTX 970<br />
- GPU: GeForce GTX 970 (GM204)<br />
- Core Base Clock: 1050MHz<br />
- Core Boost Clock: 1178MHz (Upto 1268MHz Boost)<br />
- Memory Clock: 7010MHz <br />
- Memory Size: 4096MB Samsung GDDR5<br />
- Bus Type: PCI Express 3.0<br />
- Memory Bus: 256-bit<br />
- CUDA Cores: 1664<br />
- DirectX 12: Yes<br />
- DVI Port: 1x Dual-Link DVI, 3x DisplayPort & 1x HDMI<br />
- DisplayPort: Yes <br />
- HDCP: Yes<br />
- HDMI: Yes<br />
- Power: 2x 6-Pin<br />
- 450W PSU Required<br />
- 145W TDP<br />
- Dimensions: 268.6 x 98.4 x 40 mm<br />
- Warranty: 3yr<br />
Was [£335.99] Inc. VAT
Only £299.99 inc VAT.
ORDER NOW
Asus GeForce GTX 960 DirectCU2 OC Strix 2048MB GDDR5 PCI-Express Graphics Card @ £185.99 inc VAT
ASUS Strix GTX 960 is an all-new gaming graphics card packed with exclusive ASUS technologies, including DirectCU II for 30% cooler and 3X quieter than reference; 0dB fan technology for light gameplay in total silence; and Blu-ray movie playback that's free from distracting background noise.
ASUS STRIX-GTX960-DC2OC-2GD5 with factory-overclocked 1291MHz GPU boost clock and 7200MHz memory speed. And also, 1317MHz GPU boost clock in OC mode provides 12% faster gaming experience. The cards with exclusive 4+1 phase Super Alloy Power components for enhanced durability and reduced 15% power noise than reference, also bundled with GPU TWEAK + XSplit Gamecaster provides easily stream and real-time intuitive graphics tuning and monitoring. All the cards come equipped with 3x DisplayPort interface to support 4K resolution surround.
Features:-
- NVIDIA Surround
- OpenCL support
Specification:-
- GeForce GTX 960
- GPU: GeForce GTX 960
- Memory Size: 2048MB GDDR5
- Memory Bus: 128-bit
- CUDA Cores: 1024
- DirectX 12: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Power: 1x 6-Pin
- 350W PSU Required
- 120W TDP
- Warranty: 3yr
Was [£189.95] Inc. VAT
Only £185.99 inc VAT.
ORDER NOW
Inno3D GeForce GTX 960 OC 2048MB GDDR5 PCI-Express Graphics Card (N960-1DDV-E5CNX) @ £161.99 inc VAT
The GeForce® GTX™ 960 delivers incredible performance, power efficiency, and cutting-edge gaming technologies that only NVIDIA Maxwell™ technology can offer.
This is the perfect upgrade to advanced gaming, letting you dominate the competition with 60% faster performance and twice the power efficiency than previous-generation cards*. Unleash its massive overclocking potential and push your performance even further. Plus, it features VXGI for realistic lighting, support for smooth, tear-free NVIDIA G-SYNC™ technology, and Dynamic Super Resolution that enables 4K-quality gaming on 1080p displays.
The GTX 960 even gives you great gaming to go with NVIDIA GameStream™ technology that lets you stream PC games to NVIDIA SHIELD™ devices. *Compared to GeForce GTX 660
Features:-
- NVIDIA Surround
- OpenCL support
Specification:-
- GeForce GTX 960
- Core Boost Clock: 1241MHz
- CUDA Cores: 1024
- DirectX 12: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Power: 1x 6-Pin
- 350W PSU Required
- 120W TDP
- Warranty: 2yr
Was [£169.99] Inc. VAT
Only £161.99 inc VAT.
ORDER NOW
MSI GeForce GTX 960 Gaming 2048MB GDDR5 PCI-Express Graphics Card - Red @ £169.99 inc VAT
Features:-
- NVIDIA Surround
- OpenCL support
Specification:-
- GeForce GTX 960
- Core Base Clock: 1216MHz
- CUDA Cores: 1024
- DirectX 12: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Power: 1x 8-Pin
- 350W PSU Required
- 120W TDP
- Dimensions: 267x139x36mm (812g)
- Warranty: 3yr
Was [£175.99] Inc. VAT
Only £169.99 inc VAT.
ORDER NOW
Some absolutely incredible deals on 9xx series range there, this pretty much gives OcUK the best pricing in the UK and we are the only company that has NVIDIA reference design 980 and 970 available! :)
Gibbo, sorry to post over here, but hoping you more likely to see this.
poste in CS about order OC1964258 - in order queries section.
Could you get someone to have a look?
Wouldn't touch any 970 with a barge pole. :D
To be fair, for 99% of people a 970 is a great card. At settings that induce big problems there arent any other cards that perform significantly better anyway. 980's running at 14fps but 970's running 11fps is hardly a comparison worth worrying about.
As long as you are aware of the true specifications of the 970 and how it works it’s still a good card, you just won’t be able to push it quite as far or for quite as long as we first thought. Still at the price listed it’s definitely a card to consider if you’re coming from a sub 7 series card.
Now if only I had some spare money, maybe from a refund of some sort, two 980’s at some of these prices would be very tempting. ;)
Wow, £559 for a card with a 256bit memory bus. When was the last time/generation this happened? I know that memory speeds have increased dramatically and architectural changes are huge over past Gens, but NVidia must be creaming the profits in on these relatively cheap to produce PCB's.
Just kidding but it's definately made me lean towards a 980, the cheapest EVGA 980 not in this sale, KFA2 980 SOC is an excellent deal but EVGA has superior warranty.
Doesn't look like it, Gibbo said that they sold more this week so far (Mon/Tues) than this time last week. Still it's only mid week :p
And here we have an 8GB 290x going for £330, no wonder AMD finances are in the ****.
I cant help think with the 970 over hyped memory issue that NV will not launch a 975 card or whatever they want to call it just to put it to bed.
The 970 is still the same card many have had for some months, I just think NV will have to draw a line under it sooner than they usually would have by refreshing their line up.
It's been massively over exaggerated.
Most of the people discussing it and making a big deal don't even own a 970
Yet it holds it's own perfectly.
Have you been hiding under a rock for a couple of generations?
GTX690 was £999....
great deals...very tempted with the KFA2. I currently use a 2500k (stock speed). do you think that will bottleneck the graphics card at all? Must admit its been a while since I've been on top of things...I tend to only read up on CPUs etc at the time of buying. As far as I gather, the cpu raw speed hasn't gone up that much, but I'm sure the efficiency and actual performance per mhz has prob gone up since then
