1TB Portable HDD Your data on the go
22 Apr 2014
This small and compact 1TB USB 3.0 Portable hard drive is great for transporting around all your files as needed. Put your steam folder on it and take your games portfolio with you anywhere!
Verbatim Store 'n' Go 1TB Portable External Hard Drive USB 3.0 Black (53023) @ £42.98 inc VAT
Features:
  • USB 3.0 Super Speed data transfer
  • Transfer documents and data easily between home and office
  • Safely back up and store all your files from your PC or laptop
  • USB plug 'n' play (no additional power required)
  • Stylish slim design fits neatly onto your desk top and allows it to be transported easily
  • 'Nero BackItUp Essentials' software - create your own 'back up' from your PC/Laptop hard drive to your portable hard drive
  • Quick Start Guide printed in 27 languages
The Verbatim Store n Go portable hard drive features high performance storage using a USB 3.0 “Super Speed” interface. USB 3.0 offers up to 10 times faster data transfer rates than USB 2.0 (based on USB bus speed) providing ultra fast data transfer on the go
Store and carry your digital and day to day working files on this truly mobile drive. Its stylish smooth design sits neatly on the modern desk top as the perfect accompaniment to your laptop.
Store n Go portable hard drive is USB 3.0 bus powered (1 x USB 3.0 interface) yet is backwards compatible to any USB 2.0 ports on your PC or notebook. The drive requires no external power for operation; simply plug n play.
Store 'n' Go Portable Hard Drives are formatted in FAT32 enabling you to use them on Windows OS and Mac OS systems.
For added security Nero BackItUp Essentials software is provided to help back up your laptop or PC's hard drive. BackItUp Essentials provides an application to back up all your files, folders, and drives whenever you want, or schedule the auto back up to a set time for added security.
Nero BackItUp Essentials Software is compatible with Windows XP, Vista, Windows 7 and Windows 8 (not compatible with Mac OS)
Verbatim Store 'n' Go Portable Hard Drives also comes with Green Button energy saving software. Green Button software suspends the hard drive from spinning while not in use increasing efficiency and saving energy
There are 3 'Sleep Setting' options. Set the suspend mode to come in after 10 minutes of use, or by increments of 10 minutes up to 120 minutes. Set the drive to suspend immediately by double clicking the Green Button icon on the desktop, alternatively you can set the drive to 'Never Suspend the disk'
Was £49.99 Inc. VAT
Only £42.98 Inc. VAT
ORDER NOW
What is the reliability like on these? I am after a small 1tb HDD for extra backups but want to know it will work after not being used for ages on that rare moment I will need it and not whir up clunking and clicking :)
Hi
Do these have any sort of security, so if it's nicked can people access your files?
Integrated into the drive hardware or bundled with software? Not for £42 it doesn't.
If security is that big of an issue for you then use your own encryption solution. There are many available - BitLocker as a native windows solution or one of the many other tools out there.
Hi
Not at £ 42 they do. however may of the best free backup programs have options to encrypt the backups as well. Most paid for backup software also have encryption options.
