** BECOME A PROPER BENDER **
rjk
rjk
OcUK Staff
8 Aug 2007
Hi Guys
Monsoon Bending Kits are back in stock.
These things fly out so be quick if you want one.
Monsoon Hardline Pro Bender Kit 3/8 x 1/2 (13mm) - Value Bundle @ £64.99 inc VAT
World Class Tools. World Class Results. Make sure to check out our How-To tutorial videos below for all the information, tips, and tricks you need on using these outstanding tool kits.
Included Tool Kits:
Mandrel Kit: Everything you need to fixture and bend acrylic hard lines.
- Includes mandrels in 45°, 90°, 180°, and 360°.
- Mandrels feature extended support "arms" that hold your tube in position while bending and set the precise angle you want.
- Mandrels feature polished center line channels that help maintain the tubes round shape while bending and allow the mandrels to perform double duty when mounted to your building board-they can be used to bend or as holding fixtures.
- Center line capabilities make loop planning, measuring, and using the fixtures very easy by eliminating all the hassle of inside/outside bend radius and top/bottom positioning.
- Each mandrel has one or more thru-holes that allow you to easily mount it flat to your building board and the included 90 degree brackets allow you to mount the mandrel vertically so you can fixture or bend in two planes simultaneously.
- Machined from solid aluminum and anodized for maximum durability and long service life.
- Tube channels are polished to prevent marring the tube while bending.
- Mandrels are clearly laser marked for bend radius and include hash marks in 1 degree increments.
- Mandrels are also color coded by tube size-Red for 1/2 x 5/8 (16mm) and Blue for 3/8 x 1/2 (13mm) to make grabbing the right size easy for pro modders.
- Includes all screws, brackets, hardware, and hex wrench.
Cutting Kit: Everything you need for clean, precise, square end cuts in acrylic hard lines.
- Includes a machined aluminum miter box for making clean, precise, perfectly square end cuts in acrylic hard lines-the first time, every time.
- Miter box is polished and anodized for maximum durability and long service life.
- Miter box is color coded by tube size-Red for 1/2 x 5/8 (16mm) and Blue for 3/8 x 1/2 (13mm) to make grabbing the right size easy for pro modders.
- Miter box is sized specifically for 3/8 x 1/2 (13mm) tube so the tube stays in place.
- Includes a 6" hand saw with an extra blade and a simple lever operated blade changing system.
- The saw blades have teeth specially designed for making smooth clean cuts in acrylic.
- Includes an inside/outside tube reamer to easily clean and deburr the end of your tube after cutting.
Measuring Kit: Everything you need to take advantage of the built in Center Line capabilities of our fixture and bending mandrels. This measuring kit makes loop planning and measurement right inside your case fast, easy, and most importantly, very precise. No need to worry about inside or outside diameters, top or bottom positions, K Factors, or any of that hassle.
- Precision laser cut from 3mm thick acrylic.
- Dimension markers are silk screened and are in 1mm increments.
- Includes one (1) 300mm rule, one (1) 200mm rule, and four (4) 100mm rules.
- Includes two (2) 45° and two (2) 90° acrylic brackets for planning and measuring complex loop paths.
- Includes all hardware.
Heat Gun Kit: Everything you need to heat your acrylic tube for proper bending and to prevent you from getting burned.
- 1800 W heat gun with 2 heat levels.
- Chrome plated metal diffuser to help focus the hot air where you need it.
- Cotton gloves to protect your hands.
- Solid silicone bending insert to prevent the tube from collapsing while you're bending it.
- Silicone insert is custom molded to the correct ID for your tube-no sanding or struggling to insert or remove it.
Was £73.92 Inc. VAT
Only £64.99 inc VAT.
ORDER NOW
Monsoon Hardline Pro Bender Kit 1/2 x 5/8 (16mm) - Value Bundle @ £64.99 inc VAT
Included Tool Kits:
- Miter box is sized specifically for 1/2 x 5/8 (16mm) tube so the tube stays in place.
Was £73.92 Inc. VAT
ORDER NOW
Be careful, there was a very recent court case where a female artiste won damages from a company that used her figure on their t-shirts without consent/royalties. ;)
I dont really understand your point.
Do we get hookers instead of haribo with every purchase?
we keep the haribo on pallets in the warehouse.
I think there may be some legal implications of keeping hookers on pallets in our warehouse.
will have to check
will have to check
Can I get a job at OCUK warehouse, working on the QC / testing of the hookers?
:D
http://www.bbc.co.uk/news/entertainment-arts-30932158
Read the above articel and then look at how you are promoting some of your goods, then seek legal advice. ;)
are you for real?
posting a gif on an internet forum needs absolutely zero legal involvement.
if the monsoon bending kits had trademarked likenesses on them, then yeah you would have a point
but trying to make out that we are breaching copyright by referencing a character from a TV show on an internet forum is frankly, laughable.
Hi rjkoneill, I am a representative of Matt Groening, whom as you are most likely aware, is the producer and creator of various popular animated TV shows.
I am here to initiate court proceedings based on the illegal use of our characters to promote your products. Please forward me on your details so I can formally sue you for everything you have.
Thanks
Thanks
Thank you for your interest in this thread.
I await your mickey mouse court letter appertaining to this subject.
In the interests of staying true to form, here is a relevant gif to support my statement.
The above likeness portrayed in imagery has not been used with the express permission of The Walt Disney Company and should not be considered a promotional tool to assist in sales of unrelated computer modification tool kits. Any promotional use of this image, coincidental or otherwise has not been used to represent Overclockers UK or its affiliates and is the sole internet property of rjkoneill™
Trust me, you have almost a thousand years to wait till the legislation against robot hookers is even written. :p
probably the same sort of time frame it would take to successfully sue me for posting a gif on the internet.
Hi rjkoneill, I am a representative of Disney.
Thanks
