- 30 May 2012
- Bristol
So I've been playing BF4 and found an annoying issue that has only recently started happening (I hadn't changed anything prior to this). I'm playing normally for about 30-40 minutes or so and then all of a sudden the frame rate drops massively and the game becomes a slide show for maybe 20 seconds, then it goes back to normal for about 20 seconds and so on. Upon checking GPU usage I found that it was wildly fluctuating between 0 and 50% while the frame rate was low. Has anyone else experienced this? I'm on the latest 14.12 Omega drivers.
It's just strange because it takes about 40 minutes to start happening so doesn't actually make a difference on short games but it gets annoying towards the end of conquest where I basically can't play
