I am OC'ing my MSI GTX 970 Gaming 4G and Gainward GTX 970 cards and I want to get the most out of them
Right now I have my MSI's running 1114@1300MHz core and 1753@1903MHz Ram. Powertarget is set to max th 110%. Max boost core 1502MHz.
The Gainward's are running 1051@1231Mhz core and and 1753@19003MHz Ram. Powertarget is set to the max 106%. Max boost core 1420MHz.
How much Voltage is safe for them to give ? The Voltage slider in MSI Afterburner maxes out at +87mV. It that safe to give both my MSI and Gainward cards ?
Some times on the MSI's it get the message than signal was lost to the GPU and has been reconnected. When this happens my OC settings return to stock. Happens mostly when Unigine Heaven 4.0 finishes a benchmark run.
Will increasing the Voltage help on this to get it stable ?
