A Budget Gaming Build AMD/Intel
For a single 1080 why bother with anything other than a 270X or 750ti?
With these 450w to 550w would be fine.
You could hesitate to add an SSD initially, but a 120gb or 240gb would do for the OS drive and not cost too much. It makes it all a lot more snappy. Do you have an OS?
YOUR BASKET
1 x Intel Core i5-4690K 3.50GHz (Devil's Canyon) Socket LGA1150 Processor - Retail £191.99
1 x Asus GeForce GTX 750Ti 2048MB GDDR5 PCI-Express Graphics Card (90YV05J0-M0NA00) £109.99
1 x Gigabyte Z97P-D3 Intel Z97 (Socket 1150) DDR3 ATX Motherboard £61.99
1 x TeamGroup Vulcan RED 8GB (2x4GB) DDR3 PC3-19200C11 2400MHz Dual Channel Kit (TLRED38G2400HC11CDC01) £53.99
1 x EVGA 430W 80 Plus Power Supply (100-W1-0430-KR) £32.99
1 x Raijintek Themis Black Heatpipe CPU Cooler PWM - 120mm £19.99
Total : £480.54 (includes shipping : £8.00).
This might sound like a stupid question, but if I were to buy the motherboard this week and wait until the end of February to buy the CPU, what are the chances the i5 4690K will be in stock or still be in production? This has happened to me before when I built a laptop with a retailer. I opted for the GTX 860m and when I'd saved the cash to buy the laptop, they were no longer doing it with an 860m because Nvidia had just released the new 900m line. That took the price up a fair bit which stopped me being able to afford it. I don't want to buy the motherboard and in a month or two, Intel stop supporting the socket etc lol :D
The reason I ask this is because I've been hearing something about Intel Broadwell.
The i5 4690K was only released in June last year. You won't have any problems getting one at the end of Feb.
Broadwell is also compatible with Z97 boards. They are due out sometime this year (Maybe 1st half 2015)
SuperFlower PSU's are new to me. Are they any good? I always thought, Antec, Cooler Master and Corsair were the only way to go in regards to a PSU?
Because on a lot of games with high settings they will struggle.
For a budget gaming build as the title suggests it was only a consideration for the OP.
Not actually aware of any game those cards cannot play, nor aware of anyone who expects to run the latest eye popping titles at ultra high settings with a GPU under £200 within a budget gaming rig.
Most seem to think the 750 ti, 270X, 285 as the cards to look at under £200, with the better value being the lower cost models in budget gaming rigs, even Custom PC and PC Format show such GPU's as the choice for 1080p and budget rigs.
CPU: AMD Athlon X4 860K Black Edition
Motherboard: MSI A88X-G45
GPU: Asus GeForce GTX 750Ti
RAM: Avexir Core Red Series 8GB
CPU Cooler: Raijintek Themis Black Heatpipe CPU Cooler PWM - 120mm
PSU: Corsair CS650M 650W Semi-Modular 80+ GOLD Certified
Case: Searching for one
A lot of people have told me to go for the i5-4690K and I understand that it's a better CPU, but I used to own an i5-4670K based system and I never once used it's overclocking features. If I paid £200 for the i5-4690K it would simply be a waste of money and I don't think I'd want to overclock it because I'd be too worried about destroying it. With the AMD Athlon X4 860K Black Edition, I can learn to OC without the fear of destroying the CPU because it's a lot cheaper to replace. I'm not 100% sure, but I don't think warranty covers OC damage? I'd still have my old i5-4670K based system if it wasn't for personnel problems which came up at that time which forced me to have to sell my rig.
Is that a good budget build or should I change it a little? I already have some HDD's and sometime in the near future, I'll buy an SSD for it and maybe an AIO water cooler for the CPU. I'd like to get the Fractal Design Define R5 for this build. However, it's a little expensive so I might need to look around for a different case. I do like the sleek minimalistic look of Fractal cases.
You are paying over the odds on the PSU.
£90 on the motherboard is a lot, many A88 £50'ish ones will overclock just fine too.
Bgrade GTX760 for the same price as that 750ti - http://www.overclockers.co.uk/showproduct.php?prodid=BG-372-MS
Bgrade GTX750 - http://www.overclockers.co.uk/showproduct.php?prodid=BG-424-MS
A good sleak case thats like a R5 is the Antec P100.
YOUR BASKET
1 x **B Grade** MSI GeForce GTX 760 OC Gaming Edition 2048MB GDDR5 PCI-Express G (GX-206-MS) £109.99
1 x Gigabyte G1.Sniper A88X AMD A88X Chipset (Socket FM2+) DDR3 ATX Motherboard £79.99
1 x AMD Athlon X4 860K Black Edition 3.70GHz (Socket FM2) Kaveri Quad Core Processor (AD860KXBJABOX) £67.99
1 x Antec P100 Mid Tower Silenced Computing Case £62.99
1 x Avexir Venom Series 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Memory Kit (AVD3U16000904G-2CIG) - Green Light £59.99
1 x SuperFlower Golden Green HX 550W "80 Plus Gold" Power Supply - Black £52.99
Total : £443.54 (includes shipping : £8.00).
YOUR BASKET
1 x Gigabyte F2A88X-D3H AMD A88X (Socket FM2+) DDR3 Motherboard £62.99
1 x TeamGroup Elite Black 8GB (2x4GB) DDR3 PC3-12800C11 1600MHz Dual Channel Kit (TPKD38G1600HC11DC01) £49.99
Total : £416.54 (includes shipping : £8.00).
Or fort a cheap CPU that you can overclock and not cry too much if you kill it due to the cheap cost then the Pentium K fits that bill,
YOUR BASKET
1 x Asus Z97-P Intel Z97 (Socket 1150) DDR3 ATX Motherboard £70.99
1 x Intel Pentium K Anniversary G3258 Socket LGA1150 Processor - Retail £57.59
Total : £418.14 (includes shipping : £8.00).
The PSU is what worries me. If I OC will it have enough power for the CPU/Motherboard and does the motherboard support the TDP of the CPU if I overclock it? I've been told to "watch out" for this. lol
The PSU does have the power to run that setup and overclock.
The boards support the CPU.
I have overclocked many Kaveri APUs in the Sniper for instance, the Athlon is based on the same architecture.
Remember to add the cooler to those specs.
What operating system do you intend to use? Do you need an optical drive?
The NZXT 340 is a very tempting case, even I keep looking at it, quite simply elegant in it's simplicity if it fulfills your needs, I have an old ATX system I want to rehouse, and am torn between the R5 and 340.
Another group of cases similar to the R5.
YOUR BASKET
1 x Silverstone TemJin TJ04 Evolution Midi Tower Case - Black (SST-TJ04B-E USB 3.0) £99.95
1 x Antec P280 Super Midi Tower Case - Gun Metal Black £94.99
1 x BitFenix Ghost Silent Tower Case - Black £77.95
1 x Cooler Master Silencio 550 Silent Tower Case - Black £69.95
1 x Cooler Master Silencio 452 - USB 3.0 ATX Case - SD Card Reader £64.99
1 x NZXT H230 Classic Silent Midtower Case Black £59.99
Total : £508.32 (includes shipping : £33.75).
Nanoxia look similar too.
YOUR BASKET
I intend to use Windows 7 and Windows 10 when it is released. That's only if it is any good. If it is anything like Windows 8, I'll be sticking with Windows 7.
