***The Vapers Lounge*** 2.0
Status
Not open for further replies.
Sorry about the poor picture quality, Light is pretty poor this morning, and I only have my cheap camera charged.
Does anyone have any good ideas around keeping your wire spools tight, maybe with a dispenser or something similar?
My spools don't have notches in and I have to resort to putting sellotape across the wires after I'm done but it's a bit of a pain.
Drill a hole in the side of the spool and thread the wire back into it
** Please don't hotlink images **
Jeebus, that's one hell of a drip tip :D
Seen them on fast tech but never seen someone use one, whats it like? lol.
cheers
Yip its a monster. Cracking tip to use for direct lung inhales. Great for dripping straight onto the coils as well
I use nail clippers to cut notches in the side of the spools.
This ^
I just use wire cutters, clip a notch into the side of the spool, unwrap one wrap from the side of the spool for 1 coil clip it off, or two wraps for 2 coils clip it off, bend it down in the notch, sorted.
Although its not fool proof, if you saw a few pages back, I left my spool on my desk my cat knocked it off and a full 50m spool of 24g kanthal went TWANG and unravelled took me a good 45 mins to wrap it back up without loosing a few meters of wire. :D
I use bobbins for seeing machines and poke the end though a hole, Todd had one design for fishing line that held 8 bobbins he got from fleabay.. I have vape Mail.. Just cleaning the tank; will post a pic in a bit.. :)
EDIT:
tonight vaportainment:
been looking forward to Strawberry fields since you guys says it taste more like funny feet than mothers milk. I'd ordered the subtank mini before I read of the issue of the RBA, I've just tested mine, and it doesn't always detected I just have to screw it in harder (That's what she said) and it works. Also seen that kanger is release different colours of o-rings for the tank, so I will be getting some black and grey ones. Yeah I'm a fashion victim.
I do need to pick up a toolbox for all my vape gear at some point, need one with lots of small compartments, my tubbleware boxes are just getting bigger and bigger making hard and a mess to find stuff.
Speaking of drip tips, does anyone know what that short black drip tip is that rip trippers uses?
He's mentioned it in his vids a few times, I cant remember what it is though. watch a few and he's bound to mention it. :)
I just use some fat elastic bands. :)
I hope you have better luck with it than I did. It had a harsh, gritty throat hit in any device I tried it with for some reason.
I'm not liking it tbh.. It maybe my setup with me sub-ohming it but I'm finding it a washed down version of mothers milk, it's a lower nic level than I normally vape but it's giving me head rushes lol, I might try the 8mg juice that c9v sent me on the subtank.
I'm going to stop spending for a bit as everything I'm getting gives the same taste and clouds at the moment; no matter how much reviewers say it's better.
Any recommendations of juice to sub-ohm with?
Edit: no custards thou.. Custard only belongs on apple pie in a bowl :)
I dunno tbh. I don't really buy many juices these days unless I've run out of homebrew.
While we're asking (and because I'm running low :D), anyone wanna recommend a nice, refreshing fruity juice? Nothing too sickly sweet.
my latest setup which I cant put down, all my other drippers have been sitting in the bits box.
Its just so smooth, high vapour prefect amount of flavour!
Little Boy RDA using the big bore driptip supplied with it so happy with it for ~£20
Sigelei 150w
10 wraps 24g gplat style wire
coming out at 0.4ohms
Vaping it at 60 w 5.3v
I order most of my juices from here, http://witcheliquid.co.uk
I've tried lemon and lime (daily vape), cherry menthol (will be my daily vape after my next order) and black current. All have been nice and tasted like it says on the label, for the price it's not bad at all.
Just had a look and it seems the lowest they go is 0 or 8mg sadly for me. Cheers though :)
I'll just get some more flavouring and whack up a fruit batch since it doesn't take long to steep before it's vapable.
Status
