- 19 Nov 2011
Hi all..
so....I'm looking at buying a 980 at the moment, and have my eye on this KFA2 for £400 + delivery at the moment.
I plan on using it on my oculus rift however, currently suffering with a gtx570 which just isnt able to cope with proper games just the rift demos. For the rift I have read that on using the 1080p display, detail improves significantly when using DSR.
Now due to the current 970 3.5gb issue, and 980s not being much more, I'm wondering if I should wait for the 980ti or other 8gb models, as when pumping extra through using DSR that the 8gb would be extremely beneficial.
However....there is the obvious cost to consider.....if it was going to be say £800 for example then it would be impossible to justify....but if not much more of a premium then perhaps could be worthwhile
