has anyone got the Fractal Design Define R5
3 Aug 2014
Slamannan Falkirk
as the title has anyone got the Fractal Design Define R5 case?
ive been looking at cases and like the look of this one.
any opinions on it?
I don't do big builds, but I must admit the R5 has got me tempted, it's a good job I'm too poor to seriously consider it!
yea its a nice price but there is more expensive cases out there.
and yip ill need to save for it too...
I got an R5 I've owned a tonne of cases over the years and this one is utterly superb. Easily the best. I do love Fractal cases though but its always on merit. Seriously buy one!
cheers for that. have you any pictures?
I had been looking at the corsair 300r but then I saw the R5 and decided it was a better option. dearer but more flexible with the removable drive bays
if you were to remove the lower hard drive cage install an ssd in one of the rear ssd holders and even do the bungee mod with your 3.5 hard drive in the dvd rom cage you would be good.
I got the R4 and R5, I was worried it wouldn't really be a step up or improvement but I was pleasantly surprised and for the price I think its an awesome case.
What I'd like to know about the Define cases is if they do actually increase low noise performance, are they actually quieter than a bog standard case as this is probably the main reason I'd be looking to get one.
Main reason why i stuck with fractal as i cant fault them for the low noise level performance and always worried if i change would i be worse off. The R5 was better for me in this department over the R4
