Hello chaps
I'm putting together a scope of works for the complete refurbishment of a 1900's victorian mid-terrace which is going back to brick (so new everything) and I'm curious about two things: underfloor heating and complete re-insulation.
The contractors I've met with have recommended I do not bother reinsulating under floor boards or external walls as the cost wouldn't justify the benefit (being solid wall, brick built house).
Now I've also been looking into underfloor heating, partly as a way to keep things clean and neat without the need for radiators, partly because I've heard it gives a more uniform temperature around the house.
So questions I need answered:
1. If you were going with underfloor heating, would you go with a wet system connected to your new system boiler or a dry electric system? Whole house or only some parts?
How would it work and how much is it likely upfront cost and typical running costs? I hear UF heating is kept on 24/7 which sounds a bit mental to me and if electric I'm probably looking at what, 5k per year in running costs?
2. Would you reinsulate the entire house including external brick walls (this will shave off about 4cm of internal space in each room, and add about 15k to the cost of the refurb which is a lot considering the entire budget is 75k however I cannot help but feel that without insulating the house properly any benefit achieved from UF heating would be offset by the poor thermal retention of the house)
Thanks in advance
Thanks in advance
