in theory.........can you do this
30 Sep 2006
Midlands, UK
think this may have been asked before, but...
gaming gpu (nvidia 970) and rendering gpu (quadro 2000D) installed in the same pc (assuming pc has 2 x pcix16 slots).
Obviously want to use the 970 for gaming and the 2000D for rendering/animation etc.
Option 1
Boot into bios choose with primary graphics adapator to use for this session.
Option 2
Boot normally using say the 970. With some 3d type apps you can choose (eg using openGL) which gpu to use for the rendering etc.
In theory could this work?
I am fairly sure this is possible.
In fact Linustechtips did a build with a GTX 780 for CUDA and a Quadro K4000 for whatever a Quadro K4000 is for.
Hopefully this helps :)
Yes. To make an adapter primary you just connect a monitor to the one you want to use and in windows display settings make it the main one by ticking the check box. Rendering/gaming will happen on the active display/card.
Aaagghh.....whilst mildly interesting, i watched all 57mins only to find that he doesn't go into using both gpu's. He just installs them and that's that. :rolleyes:
