TeamGroup Xtreem LV 16GB (2x8GB) DDR3 PC3-21300C11 2666MHz Dual Channel Kit (TXD316G2666HC11CDC01) @ £107.99 inc VAT
Team Xtreem LV is the most popular overclocking and gaming gear in the LAN party. Based on the memory architecture evolution on Intel Core i7, Team raises the frequency of the Xtreem LV DDR3 by 20% from 2000MHz to 2400MHz. Also, by continuing the high frequency and low latency tradition of the Xtreem LV memory, the Xtreem LV DDR3 2400 can fully display the configuration 9-11-11-28 (tCL-tRCD-tRP-tRAS) at a low operating voltage at 1.65V without sacrificing either performance or stability. All these have witnessed the extraordinary R&D capacity and capability of Team. In addition to the unchanged genuine chip policy, Team ensures chip quality with the exclusive sorting technology to screen chips. In order to further ensure the optimal performance and flawless quality of the Xtreem LV DDR3 2400, Team applies the 24-hour burn-in test and industry-approved MemTest software to perform the OQC inspection of all modules before shipping to assure the stability and exceptional performance of every Xtreem LV DDR3 2400. The Xtreem LV DDR3 2400 from Team has a conventional 8-layered PCB design and is covered with the X-mark heat-sink labeled for the Xtreem series. In addition to the clean appearance as found in all Team Xtreem memory modules, a groove has been added to the heat-sink for power users to install fans on top to enhance ventilation. For more information on this product, please visit the Team Group website at: www.teamgroup.com.tw.
Features:-
- Module Type 240Pin Unbuffered DIMM Non ECC
- CL-tRCD-tRP-tRAS 11-13-13-35
- DRAM Density 128x8 / 256x8 / 512x8
- Data transfer bandwidth 21,300MB/Sec (PC3 21300)
- Heat Sink Aluminum heat-sink
- Working voltage 1.65V
- Warranty Lifetime warranty
- Note Intel XMP1.3, compatible with series Intel 7 chipsets and higher.
Only £107.99 inc VAT.
ORDER NOW
________
CLEARANCE OcUK Ultima 7" IPS 8GB Tablet PC - Android ICS 4.0 /w Playstore (30 Days Warranty) @ £29.99 inc VAT
**CLEARANCE/REFURB PRODUCT: NOT BRAND NEW!**
OcUK Ultima tablets use a combination of the fastest hardware to ensure gameplay is smooth and response is instant. The other major advantage is they use Super-High resolution IPS screens for incredible image quality along with great viewing angles. They also come housed in very high quality and extremely thin chassis making them stunning to look at as well making you the envy of all your friends.
OcUK Ultima tablets are unbeatable for the money and their performance cannot be matched at this price point and the screens making using them a joy. They also feature aluminium ally back plate which further adds to the quality of these tablets, for the money these are unbeatable!
Specification:-
- Processor: Cortex A9 1.20GHz powerful processor
- Graphics: Mali 400 MP 3D Hardware Acceleration
- Display Screen: 7" Super Resolution 1024x600 IPS LED Backlit screen
- Operating System: Andoid ICS 4.0 /w Playstore
- Language: Multiple language support (English Default)
- Memory: 1GB DDR3
- Storage: 8GB NAND Flash (Upgradable to 32GB /w SD card)
- Memory Card: Micro-SD (Support upto 32GB)
- G-Sensor: Yes
- WiFi: IEEE 802.11b/g/n wireless network
- Touch: Capacitive screen
- Mini-USB Port
- Mini-HDMI supporting 1080P Video output
- Video Decode: AVI (H.264, DIVX, XVID), RM, RMVB, MKV, WMV, MOV, MP4?H.264, MPEG, DIVX, XVID), MPEG, MPG, FLV. HD 1080P max.
- Music Decode: MP3,WMA,MP2,OGG,AAC,M4A,MA4,FLAC,APE,WAV
- Picture Format: JPG, JPEG, GIF, BMP, PNG
- Camera: Front 0.3M/Rear 2.0M
- Battery: 2800maH / 3.7v
- Battery life: 4hrs
- Dimensions: 184 x 121 x 8.5mm
- Warranty: 30 Day Clearance
Only £29.99 inc VAT.
ORDER NOW
Features:-
ORDER NOW
________
Specification:-
- Memory: 1GB DDR3
- G-Sensor: Yes
- Mini-USB Port
ORDER NOW
