** SAPPHIRE WITH AN 8GB CARD FOR EVERY OCCAISON!! **
OcUK Staff
17 Oct 2002
OcUK HQ
Hi there
Sapphire now have three models of 290X with 8GB configuration, check them out:
Sapphire Radeon R9 290X 8192MB GDDR5 PCI-Express Graphics Card **OcUK WorldWide Exclusive** @ £329.99 inc VAT
As requested by our customers and actioned by us here at OcUK this is the worlds ONLY reference PCB and reference blower cooler 8GB card available and only exclusively from OcUK in the world. Perfect for customers who want to run 3-way or 4-way crossfire or fit waterblocks. Once again OcUK delivers because we listen to our customers!
AMD Radeon R9 290X is a new graphics card powered by the latest AMD Radeon™ R9 290X graphics-processing unit (GPU). 8GB of super-fast GDDR5 memory for the best gaming experience at the highest resolutions including 4k and incorporates AMD Eyefinity and TrueAudio technologies to enable expansive multi-display setups and more accurate environmental sounds. R9 290X also includes support for both DirectX® 11.2 and AMD's new Mantle application programming interface (API) for great handling of even the most-demanding PC games.
Specification:-
- Radeon R9 290X
- GPU: Hawaii XT
- Stream Processors: 2816
- ROPS: 64
- Core Speed: 1000MHz
- Memory Speed: 5000Mhz
- Memory interface: 512-Bit
- Memory capacity: 8192MB GDDR5
- Cooling: 2-Slot Blower Fan
- Fan Speed: 20% - 40% (Quiet Mode) & 20%-55% (Uber Mode)
- PCI-Express X16 lane required
- 750W or greater PSU required
- Power Connectors: 8-pin + 6-pin required
- Display Outputs: 2x Dual Link DVI, 1x HDMI, 1x DisplayPort
- Warranty: 2yr
Only £329.99 inc VAT.
ORDER NOW
Sapphire Radeon R9 290X Tri-X OC 8192MB GDDR5 PCI-Express Graphics Card (11226-17-20G) @ £349.99 inc VAT
The SAPPHIRE R9 290X Tri-X 8GB features the latest GCN (graphics core next) architecture from AMD with 2816 stream processing units and an enhanced engine clock of up to 1020Mhz. It is equipped with 8GB of the latest high performance GDDR5 memory on a 512-bit interface and now clocked at 1375 MHz (5.5GHz effective) delivering higher bandwidth than earlier models. Built on a SAPPHIRE original pcb, the layout incorporates a 6-phase VDDC power design. Two 8-pin power connectors ensure adequate system power is available (up to 375 Watts total including PCI-Express power).
Specification:-
- GPU: Hawaii XT
- Litecoin Hash Rate: 850-1000
- ROPS: 64
- Core Speed: 1020MHz
- Memory Speed: 5500Mhz
- 600W or greater PSU required
- Power Connectors: 2x 8-pin required
- Warranty: 2yr
Only £349.99 inc VAT.
ORDER NOW
Sapphire Radeon R9 290X Vapor-X OC 8192MB GDDR5 PCI-Express Graphics Card (11226-11-40G) **OcUK WorldWide Exclusive** @ £419.99 inc VAT
OcUK has a worldwide exclusive on the only 8GB 290X in existence, but this is not any 290X it's a highly fine tuned machine being the Vapor-X edition with near silent cooling solution. Running with a 1060MHz core clock and with memory clocked at 5600MHz makes this card absolutely perfect for a 4K setup, even more so with a pair or three of these in Crossfire. That means you could play games like Skyrim with expansion packs at 4k resolution and still not run out of VRAM.
Based on the award-winning Graphics Core Next (GCN) architecture from AMD with 2816 Stream Processors, the SAPPHIRE R9 290X Vapor-X is an Overclocked edition which boasts 8GB of the latest GDDR5 memory running at 1400 MHz (5.60GB/s effective) and high speed engine clocks of 1060MHz.
SAPPHIRE’s innovative Vapor-X cooling technology allows products to run not only cooler but also much quieter. A Vapor-X product means a virtually silent gaming experience and more headroom to explore performance tweaking!
Choke is an important component of the graphics card. By working with the component engineer, Sapphire’s patent pending choke is 10% cooler and offers 25% more power efficiency than a normal choke. The graphics card will be more reliable and save energy.
Improved reliability and better overclocking are possible by using only high-polymer, aluminum capacitors which posses far superior characteristics than regular aluminum capacitor for a longer product life. When operational temperatures drop by 20°C, the product life span is extended by a factor of ten, when the operational temperature increases by 20°C, the product life span only decreases by 10%.
Along the edge of the card the PCB is extended and one of the copper layers left exposed. An additional heatsink mounted directly to this copper layer allows heat absorbed into the PCB from the GPU and other components to be transferred to the heatsink and cooled by the airflow. This feature alone can reduce core temperature by 2 degree C.
Specification:-
- GPU: Hawaii XT
- ROPS: 64
- Core Speed: 1030MHz
- Warranty: 2yr
Only £419.99 inc VAT.
ORDER NOW
Three great cards from Sapphire, the reference is perfect for those who want heat exhausted out the case or are building into a small case, plus it is perfect for waterblocks as its an AMD reference PCB.
Then the Tri-X and Vapor-X have the stunning coolers which look superb, the Vapor-X is geared more towards overclocking and has the backplate. :)
That reference card needs to be cheaper than the special offer MSI 290X 8GB for £299.
Who would go for the reference for that price? :(
That Vapor-X is a bit expensive. It's available for £400 at numerous other retailers. Considering you guys had under £400 a while back, no chance of this being price matched?
Also, does the Sapphire Tri-X have a back plate? Doesn't look like it.
No, it doesn't have a backplate. The Vapor-X, Powercolour and MSI cards do though.
Yeah we will price match, post in CS section with a link to the competitor showing in stock and we will do our best to match it. MUST BE IN STOCK THOUGH!
Two Questions
1. Why is Vapor -X so much more higher than Tri-X?
2. Can a single one of these run 4k games at 60 fps smooth over hdmi?
It's not, trust me me :)
I won't post the link since it's a competitor, but there is the 8gb model for that price.
*cough* blind *cough*
Two Questions
Minecraft and LOL yes.. AAA titles doubt you going to get anything higher than 40FPS with medium-high settings
