** ASTRO **
  • Thread starter Thread starter rjk
  • Start date Start date
rjk
rjk
Caporegime
8 Aug 2007
We now list Astro Gaming products
These headsets work with pretty much everything, I made a handy guide for you here:
Astro MixAmp™ Pro (3AM99-AGU9X-975) @ £109.99 inc VAT
The next generation in MixAmp™ technology, we’ve fine-tuned the MixAmp™ Pro to perfect your control over your game audio. Your own personal audio mixer and headphone amplifier, you’ll be able to enhance and isolate your game audio to exactly how you need it. Get the drop on your enemies by using their own footsteps against them, or use the MixAmp™ Pro’s stream output to capture your game and voice sound. Got your friends over? You can string multiple MixAmp™ Pros together to create a lag-free private voice network.
DOLBY DIGITAL 7.1®
- Immerse yourself in stunning surround sound with our proprietary MixAmp™ technology. You’ll be able to use every gunshot and footstep to pinpoint, and get the drop on, your opponents.
MADE FOR MULTIMEDIA
- With four standard EQ settings, you can further refine your amazingly tuned gaming experience. Choose between Pro, Core, Media, and LAN.
MASTER YOUR AUDIO
- The MixAmp™ Pro is your own personal audio mixer and headphone amplifier. We developed it specifically for enhancing the audio and communications experience of video gaming.
SHARING MADE SIMPLE
- It's now easy to capture all your gaming audio for livestreaming. And when you're gaming together, you can link multiple MixAmp™ Pros together for a private network.
Specifications:-
- Inputs Rear: 3.5mm Mini TOSlink, 3.5mm mp3 connector, USB mini-B (audio/power), 3.5mm Stream Output
- Frequency Response: 20-20,000 Hz
- Power Output: 70mW 32ohm per channel
- Inputs Front: Headset Connector, 2.5mm Xbox Live voice communication connector, Two daisy chain 3.5mm ports
Ships With:-
- MixAmp™ Pro
- MixAmp Cables:
3.0m TOSlink Optical Cable, 3.0m Micro-USB Cable, 1.0m Daisy Chain Cable, PC Headset Y-Adapter
Only £109.99 inc VAT.
ORDER NOW
Astro A40 Headset Black @ £129.95 inc VAT
Always looking for improvements, we’ve upgraded our classic A40 headset to bring your PC an even better audio experience. Designed for professionals but fit for any gamer, the A40 headset is lightweight and provides long-lasting comfort, so you can play your way. Most importantly, the A40 delivers unparalleled sound with incredible clarity, allowing you to hear even the subtlest aspects of your game’s soundscape.
CUSTOMIZABLE SPEAKER TAGS
Our magnetic speaker tag system lets you personalize your pair. Buy special editions or design your own using the Speaker Tag Customizer.
SUPERIOR FIT & FINISH
Featuring premium materials and construction, ASTROs are highly adjustable and surprisingly lightweight. Clamp them on your dome for days or turn them flat around your neck.
SWAPPABLE CABLE SYSTEM
The new Mobile Cable plugs directly into the headset via a 3.5mm 4-pole jack and offers an in-line microphone, an in-line mute switch, a volume control wheel, and a call/pickup/tracking button.
TUNED WITH ASTRO AUDIO®
We work with pro gamers and top audio designers to deliver the highest level of clarity at every frequency. Your games, music, and movies will sound amazing.
Headset Specifications:-
- Transducer Principle: Dynamic, Open
- Frequency Response: 20 - 21,000 Hz
- Distortion: Less than 0.1%
- Microphone: 6.0mm unidirectional
- Nominal Impedance: 48 Ohms
- Headband Pressure: 2.6N
- Ear Coupling: Over-Ear
- Weight w/o Cable: 324 g
- Connection: 3.5mm 4pole Jack
Only £129.95 inc VAT.
ORDER NOW
Astro A40 Headset White @ £129.95 inc VAT
ORDER NOW
Astro A40 Headset and MixAmp™ Pro (A42/MA3) Black - Playstation @ £199.99 inc VAT
Always looking for improvements, we’ve upgraded our classic A40 headset to bring your PlayStation 4 an even better audio experience. Designed for professionals but fit for any gamer, the A40 headset is lightweight and provides long-lasting comfort, so you can play your way. Most importantly, the A40 delivers unparalleled surround sound with incredible clarity, allowing you to hear even the subtlest aspects of your game’s soundscape.
DOLBY DIGITAL 7.1®
MADE FOR MULTIMEDIA
MASTER YOUR AUDIO
SHARING MADE SIMPLE
MixAmp Pro Specifications:-
Compatible with: PC / PS4 / PS3 / 360* / XBox One*
* Voice requires additional Xbox components purchased separately
Ships With:-
A40 Headset, A40 Microphone, A40 Speaker Tags, Mix Amp Pro, 2.0M A40 inline mute cable, 3.0M TOSlink optical cable, 65mm PC splitter cable, 3.0M Micro USB Cable, 1.0M Daisy Chain Cable
Only £199.99 inc VAT.
ORDER NOW
Astro A40 Headset and MixAmp™ Pro (A42/MA3) White - Playstation @ £199.99 inc VAT
DOLBY DIGITAL 7.1®
MADE FOR MULTIMEDIA
MASTER YOUR AUDIO
SHARING MADE SIMPLE
Ships With:-
ORDER NOW
Astro A50 Wireless Headset Bundle Black - Playstation @ £249.95 inc VAT
Just as consoles evolve, so do our headsets, so we’ve fine-tuned and updated our A50 to make the best available headset in wireless gaming to your PlayStation 4. Broadcasting with cutting edge wireless Kleernet 5.8ghz technology, the A50 employs three varied EQ modes designed to fit your audio needs. The uni-directional microphone delivers communication to your teammates by isolating your voice from any background noise in the room. We’ve designed this headset to be lightweight and adjust easily to your cranium to ensure maximum comfort for those games that last long into the night. And when you're done it fits perfectly on its own headset stand.
DOLBY DIGITAL 7.1®
MULTI-SYSTEM COMPATIBILITY
ASTRO MixAmp™ Pro (included in all Audio Systems) and the A50 Built in MixAmp™ + Transmitter (included in all A50 Wireless Systems) ensure compatibility with any major platform you choose to game on. Whether you're gaming on a PS4, Xbox One, Xbox 360, PS3, PC, or a mobile platform, ASTRO has you covered.
5.8 GHZ WIRELESS TECHNOLOGY
Operating at a higher frequency than most wireless devices, ASTRO wireless mixamps provides clarity and range with less interference. Available on A50 wireless headsets.
Specifications:-
- Transducer Principle: Open Air
- Frequency Response 20 - 21,000 Hz
- Distortion THD < 1%
- Microphone 6.0mm unidirectional with noise gate
- Nominal Impedance 48 Ohms
- Headband Pressure 2.6N
- Ear Coupling Over-Ear
- Weight w/o Cable 363 g
- Connection 2.5mm Xbox Live Chat Port, Micro-USB Port
Tx Specifications:-
- Wireless 5.8GHz w/ KleerNet™
- Audio Fidelity 48kHz 16-bit
- Mic Fidelity 48kHz 16-bit
- Channels Stereo w/ Dolby®
- Input Micro-USB Power & Voice, Optical In, AUX In (3.5mm)
- Output Optical Passthrough, USB Charging Port
- Power USB
- Surround Technology Dolby® PLIIx, Dolby® Headphone
Ships With:-
- A50™ Wireless Headset, MixAmp™ Tx and Display Stand
- Headset Cables:
- 0.5m Micro-USB Cable
- MixAmp Cables:
Only £249.95 inc VAT.
ORDER NOW
Astro A50 Wireless Headset Bundle Black Xbox One @ £249.98 inc VAT
Just as consoles evolve, so do our headsets, so we’ve fine-tuned and updated our A50 to make the best available headset in wireless gaming to your Xbox One. Broadcasting with cutting edge wireless Kleernet 5.8ghz technology, the A50 employs three varied EQ modes designed to fit your audio needs. The uni-directional microphone delivers communication to your teammates by isolating your voice from any background noise in the room. We’ve designed this headset to be lightweight and adjust easily to your cranium to ensure maximum comfort for those games that last long into the night. And when you're done it fits perfectly on its own headset stand.
DOLBY DIGITAL 7.1®
A50 Headset Specifications:
- Transducer Principle Open Air
TX specifications:-
- Power USB
Ships With
- A50™ Wireless Headset, MixAmp™ Tx, AG1 and Display Stand
- Headset Cables: 0.5m Micro-USB Cable, 1.0m AG1 Xbox One Chat Cable
- MixAmp Cables: 1.0m Micro-USB Cable, 1.0m TOSlink Optical Cable
Only £249.98 inc VAT.
ORDER NOW
Astro A50 Wireless Headset Bundle White Xbox One @ £249.98 inc VAT
DOLBY DIGITAL 7.1®
TX specifications:-
- Power USB
Ships With
ORDER NOW
they have a very solid reputation and the mixamp is a product i felt that we really needed to offer also
not at all, i had to check
the bundle versions come with a cut down mixamp as opposed to the mixamp pro.
this can be seen in the pictures on the website.
I think it also acts as the wireless transmitter too.
The bundles come with both. No way it's £250 without the amp.
These are the best hands down for console gaming, I recently sold 2 pairs on here as I got rid of my Ps4.
EDIT: Not worth it if the amp is not the pro version =/
it does come with the amp but its not the mixamp pro
SHIPS WITH:
MixAmp™ Tx
AG1
Display Stand
I'm guessing english isnt your first language maybe?
the mayflower/epiphany ODAC solutions are absolutely nothing like these and arent intended for the same sort of userbase.
for a start, the dont offer console gaming compatibility in any way shape or form. or wireless.
the cool thing is that we actually offer the other thing you mentioned too. thats the great thing about being a retailer, we can offer multiple things and cater to everyone's needs.
They're just different products. The mixamp pro is the wired version, and the TX is the wireless version. They work exactly the same, they're both 7.1, only with the TX the controls aren't on the mixamp, they're on the side of the ear cups. Volume controls, as well as the chat / game balance. The only thing that it doesn't have is the stream output.
I can recommend the Mixamp Pro, being a PC & XB1 gamer. As someone who lives in a flat with fairly thin walls between me and the neighbours, it's pretty much perfect for me. Every sound from both my PC and Xbox comes through my Mixamp and my PC350s. I have it connected to both at the same time so I can listen to music from the PC while playing on the Xbox. I've had mine (the 2013 version) for almost two years and it still works great.
Remember, if you're like me and plan to use it with the Xbox One, you'll need to buy the Xbox One Headset Adapter (yes I know you didn't need an adapter for the 360 but this is Microsoft)
Nice to see them being stocked here :)
I've got a pair of the a50's in white. I love them, comfiest headset I've worn. Sound quality is good for games, not the best for music though. The build quality is amazing though to be fair.
SHIPS WITH:
MixAmp™ Tx
AG1
Display Stand
RJK I think you might be wrong m8 according to the astro site the packs include Mixamp Pro its just on the A50s its wireless version of the Pro.
This is great news, I've been teetering on replacing my Tritton Pro+ cans for a while now.
My biggest concern however is the mic quality. I don't doubt that the speaker quality reflects the price, but one thing I've noticed with my Pro+ is that everyone comments on how good the mic sound is. When I did a brief stint on Youtube, I even chose it over a Blue Snowball for sound quality.
I'd be looking at the A50s, but they don't come with a mixamp as per this video:
Unless there are regional differences (this video being American) then it doesn't look like it comes with a mixamp at all, merely a wireless transmitter.
That means I'm looking at £360 for both the headset and the mixamp, which I can't justify. Not that I can't afford it, but it's just too expensive, when I can get another pair of Pro+ for £150ish which although aren't wireless, are still a fantastic set and one I could live with for a very long time.
Do OcUK intend stocking Tritton any time soon? They're made by Mad Catz, the same folks who already supply your RAT mice and various other bits and bobs, so it shouldn't be too hard to get them in.
£360 how do you work that out The wireless transmitter is just wireless version of the mixamp so you dont need to buy another mixamp with it lol, the mixamp is for those using wired headsets. And i hope to god OCUk dont start stocking Tritton can not stand them they are rubbish.
Thank you for your well reasoned, well thought out points, I'm sure you'll make a great politician one day.
I've done a bit more research and according to a few sites, the Mixamp Pro isn't compatible with the A50s anyway, so that rules that one out. There are however conflicting opinions all over the net (shock horror!) about whether it's better or not than the amp included with the A50s. Some say it's better, some say it isn't.
As for Tritton, I've been using them for about 4 years now, the only issue I've ever had is that my first pair (AX Pros) had a cable break which resulted in me sending them back, and Mad Catz replaced them with my current pair of Pro+. The sound quality is great, the mic quality is great and they are comfy. I can easily sit for a few hours solid and completely forget that I'm even wearing them.
Of course your experience might be different, but let's "hope to god" shall we, that retailers don't start blocking items because "you can't stand them" and because you have a different opinion of something to someone else.
that info was taken from the astro site.
the astro site says the wireless ones come with the mixamp tx, which is what i said.
This is correct.
correct, the A50 comes with the Mixamp TX, which is a mixamp/wireless transmitter combo. It is an all in one solution that requires no additional purchases.
