You can answer your own question by looking at how many FPS you get in the games you play...i have the above card and single azuz roc moniter
is it worth buying antother gtx 780 ti for single moniter.
I have a GTX780 with a 1440p, runs fine with some setting's turned down. If eye candy is something you want then another card will help that but for me I'd rather save the money for what's round the corner...
thought it was work buying it as seen it as a b grade
