Sycho's log...4 day workout.
16 Nov 2004
London
I am trying to gain more mass and strength together so keeping reps 5-8 range on my main compound sets.My current stats are 88kg 16% bodyfat and i am 33 years old training for a year consistantly.(flu has reduced my strength this week :( ) I also train with around 70% grip on my lefthand compared to right....it gives me a disadvantage but doesn't stop me i could be stronger if it wasn't for this but my strength and shape has improved a lot so i am happy. :)
Sunday: (chest/tri)
Flatbench Press
20kg x12
30kg x8
50kg 5/6/6/8 (i think i have a trapped nerve hindering my strength a bit)
Flatbench DB Press
12kg x12
20kg x10
22kg 7/8/9
Incline DB Press
20kg 8/8/7
Assisted Dips
78kg 5/6/5/5
EZ-Bar Skullcrushers
20kg 9/10/10
Tricep Rope Pulldowns+Tricep Pushdowns Superset
15kg 7/8/7 17.5kg 7/7/6
Farmer's Walks
24kg each arm for 90s.
Monday: (Back/Bicep)
Deadlifts
50kg x12
70kg 4/5/6/6 (working on form still but it's near perfect now)
Bent Over Barbell Rows
30kg x15
50kg 8/7/7/6
Assisted Wide Grip Pullups
63kg 6/5/5/5 (really struggled on these....i am using hook grip though for more use of the lats)
Close Grip Lat Pulldowns Dropset
70kg x2 (struggled...strength is down!)
60kg x9
50kg x11
40kg x13
Barbell Curl
25kg 10/9/8
Hammercurls
12kg 8/8/7
Forgot to do DB rows....ah well next time!
Wednesday: (shoulders/triceps) Had shoulder issue for a few months so these lifts have been down a bit but all is fine now.
Overhead Press:
20kg 10/10
32.5kg 5/5/5/5/5 (was form check and felt easy so will up weight next time)
Seated Dumbell Shoulder Press
16kg x8
18kg 5/5/6
Side Lateral Raises with Front Delt Raises Superset
10kg 10/10/9 10kg 5/5/6
Seated Rear Delt Flys (?)
6kg 6/7/6 (these seem really hard....first time i try them though)
Dumbell Shrugs (4s pauses)
24kg 12/12/12
Close Grip Dumbell Press with Overhead Dumbell Tricep Skullcrushers Superset
20kg 7/6/6 20kg 10/8/9
15kg 15/13/12
That's quite some weight for someone with shoulder issues - I hate raises! If I want to suffer, I do Shoulder 21s - which is 7 sets of front, side and rear raises all superset. Try them and weep ;)
Nah i haven't had the issue for around 5-6 weeks now...i get zero ache now, just some stupid trapped nerve i think which is causing issues with flat benchpress. :( (was told they just go after a while maybe i should get it looked at....it's not painful though)
Yeah that superset sounds tough, even this one aches a lot! but the tricep one i did is awesome it's really helping me....i am surprised how little at my gym do
close grip dumbell presses i find them better than close grip bench.
Thursday: (legs/biceps) Didn't have as much volume as i wanted due to time. :(
Squats
20kg 20
50kg 8/8
60kg 6/7
70kg 3/4
Standing Calf Raises
70kg 15/15/15
RDL's
50kg 10/8/9
Walking Dumbell Lunges
10kg 8/8 (each leg)
Legpress
120kg 25/25 (was easy)
Bicep Pulldowns Dropset
60kg 10
50kg 12
40kg 15
Preacher Dumbell Curls
14kg 5/6/5
Cables Rope Hammercurls
20kg 12/10
Sunday: (chest/tri)
Flatbench Press
20kg x12
50kg 5/7/7/8
55kg 5
Flatbench DB Press
22kg 8/8
24kg 4
Incline DB Press
20kg 9/8/8
Assisted Dips (might try bodyweight soon since i am only 5 off)
83kg 5/5/5/3
EZ Bar Skullcrushers 25kg
8/7/7
Overhead DB Skullcrushers
22kg 9/8/7
V-Bar Tricep Pushdowns
17.5kg 20/15/12
Deadlifts
60kg 8/8
80kg 3/2 (form slightly went a bit down but was still good)
Barbell Rows
50kg 8/8/8/8 (these went great despite my lefthand having less grip it's improving a lot!)
Wide Grip Assisted Pullups (using hook grip)
68kg 5/5/5
DB Rows
22kg 9/9
24kg 7/7
Close Grip Lat Pulldown (Dropset after 70kg...didn't stop at all this time only to remove pin and replace...)
70kg 3
60kg 9
50kg 10
40kg 11
Barbell Curls
30kg 6/6/6
Weds: (Shoulders/Triceps)
Overhead Press
20kg x12
35kg 6/5/6/5 (weight going up gradually and reps consistant :) )
Seated DB Shoulder Press
18kg 7/6/7
Lateral DB Raises and Delt DB Raises Superset
10kg 12/10/9 10kg 9/8/7
6kg 12/10/10 (will go 8kg next week i guess?)
Barbell Shrugs (4s pauses at top)
60kg 10/9/8
Tricep Rope Pulldowns with Tricep Bar Pushdowns Superset
17.5kg 12/11/10 20kg 12/10/9
Pushups
15/15/15
Farmer's Walks
24kg (this exercise helps my grip a lot will up it to 28kg next week)
Starting Athlean X training programme in couple of weeks hopefully so will be interesting workouts. :)
Keep up the good work Sycho! From the first time I saw you to the last you made huge progress :)
Thursday: (Legs/Biceps)
Squats
20kg 20
50kg 6/6/8
70kg 4/4/5
70kg 20/20/20
RDL's
50kg 12/12/12
Walking DB Lunges
10kg 16/16 (each leg)
12kg 6/6
Legpress Dropset Narrow stance (first time i go narrow in a while)
140kg 25
120kg 20
100kg 20
Chin Ups
73kg 6/6/6
DB Hammercurls
14kg 7/7/7
Preacher DB Curls
14kg 6/6/5
Bicep Pulldowns Dropset (started getting tired here so str bit down)
70kg 5
50kg 10
30kg 15
Sunday: (Chest/Triceps)
Flat Benchpress
50kg 9
60kg 4/4/5
Flat Bench DB Press
20kg 10
22kg 10
24kg 7
Incline DB Press
20kg 7/7/7
Assisted Dips
83kg 6/5/5
Seated Angled Skullcrushers
23kg 8/8/8 (these are damn hard on an angle!)
Elbows tucked DB Press
18kg 8/8 (gave up after 2 sets as it seemed silly to do these with dips in same workout as i usually do 22kg on these)
Rope Tricep Pulldowns Dropset
17.5kg 8
15kg 8
12.5kg 8
10kg 7
Glad to hit 60kg on bench again. :D
Well since starting a new job this week my training has gone all messed up.....i can only train in around 30mins so will have to superset like crazy. :p
Think i'll just do bench/squats/dl/ohp/chinups/bors/side lat raises/dips due to this.Yesterday managed ohp/barbell shrugs/side lat/front delt/tricep pulldown/tricep pushdown in 30mins with 3-5 sets each but was tough. :D
Or... this might be the opportunity to think about what you're actually achieving by having a million different exercises in each workout. :)
If you hit two heavy compounds and two isolation exercises per session, you'll be golden, such as:
CHEST:
- Flat dumbell OR barbell bench;
- Weighted ring dips;
- Pushups ss/w tricep isolation.
Stick to 30-60 seconds rest and you'll be golden. And very sore.
I always do 30-45s rests even on main compound lifts....yeah i get damn sore too lol but getting very good results.Tomorrow i am going for legs so will do squats+standing calf raises as superset then leg curls with legpress superset....good? or should i go for rdl+lunges superset?
Since i go 4 days a week thinking of:
flat barbell bench/dips+tricep isolation superset/push ups
deadlifts+pullups superset :D/bors+bicep isolation superset
ohp/side lat+front delt+barbell shrugs superset
squats+standing calf raise superset/leg curl+leg press superset
Aiming for about 15-20 sets too on each workout....this good for 30mins each these layouts?
As previously, it seems pointlessly busy. :)
This was given to me awhile ago, might give your workout a bit of structure.
Workout
Start every workout with a few light sets of your first exercise
Day 1: Chest
Incline dumbbell press: 3 sets of 8-12 reps
Flat Bench Press: 3 sets of 8-12 reps
Incline flyes: 3 sets of 8-12 reps
Cable crossover: 3 sets of 8-12 reps
Day 2: Legs
Squat: 3 sets of 8-12 reps
Leg Extension: 3 sets of 8-12 reps
Hamstring Curl: 5 sets of 8-12 reps
Calf Raises: 5 sets of 8-12 reps
Day 3: Back & Bis
Lat pulldown medium grip: 3 sets of 8-12 reps
Lat pulldown wide grip: 3 sets of 8-12 reps
Dumbbell rows: 3 sets of 8-12 reps
Rear delt flyes: 3 sets of 8-12 reps
Barbell curls: 3 sets of 8-12 reps
Incline dumbbell curls: 3 sets of 8-12 reps
Machine curls: 3 sets of 8-12 reps
Day 4: Shoulders & Tris
Shoulder press: 3 sets of 8-12 reps
Dumbbell lateral raises: 3 sets of 8-12 reps
Front dumbbell raises: 3 sets of 8-12 reps
Shrugs: 5 sets of 8-12 reps
Tricep dips: 3 sets of 8-12 reps
Tricep pushdowns: 3 sets of 8-12 reps
Overhead dumbbell extensions: 3 sets of 8-12 reps
You could switch the tricep stuff from shoulder day to chest day, if you where keen on keeping those together.
Just food for thought really.
Yeah but that list would be damn hard in 30mins :p today i did squats+pullups superset/close grip lat pulldown dropset/legpress dropset/seated calf raises....i see what you mean mrthingyx....3 compounds+an isolation or superset compound x2+dropset could work fine aswell.
