uninterruptible power supplies
20 Oct 2002
Oxfordshire / Bucks
Is it worth getting a UPS for my bedroom ?
I can see they are around £40 + so not too bad
or should I spend a little less and just get a surge protector?
I will have the following connected to it :
Computer
Monitor
Router
External hard drive
Paper shredder
Printer
TV
DVD players x3
games consoles
Thanks
I've never used a UPS or a surge protector and have never suffered a failure of any component or device ever.
A mate of mine works in India a lot so has quite a beefy one as their power is as reliable as a chocolate teapot.
Which do you need? A surge protector (which may be useless if you have a fairly new circuit) or a UPS?
A surge protector isn't going to keep your equipment up and running or shut down your PC safely in a power cut or provide a more stable voltage.
Also, a UPS for that amount of equipment should cost a lot more than £40.
When gaming my 500VA UPS complains that it's overloaded, I only have my computer plugged in and not the monitor or anything else.
If you want a UPS to power all that you listed you're going to need a good size unit 2000VA+ which will be a LOT more than £40.
I thought UPS's have very good surge protection built in too?
They do.
I wouldn't want a £40 UPS.
This! I wouldn't get anything other than APC, which will cost you.
Wouldn't touch a £40 UPS with a bargepole personally, but imo if you need to ask if you need it then you don't need it. I'd have thought if it were an issue it would have flagged up already and you'd have one. Most places in the UK have rock solid power, I run servers at my home that have months of up time. I only had an issue with power once when the local sub station blew.
UPS are only useful (depending on what you have connected to it) for a short term power supply, mainly to give you an extra 30 minutes before backup generators kick in to keep stuff ticking over or you shut your equipment down in a controlled manor until the power is restored
Why would you bother at home? unless your running a business critical rack at home with servers or network kit
Why would you want a paper shredder on a UPS
:p
£40 is low, bearing in mind, it runs on batteries, which will run out as I mentioned before
i just bought one in the last few days - from my research its not worth getting anything other than an APC one - i got a BE700g-UK. 400w, 700VA.
this only has 4 ups sockets and another 4 that are surge protected.
cost about £85.
thanks guys
so should I get a quite a decent Surge protector then?
Surge protector yes, if you dont want your stuff frying during a storm or a surge
IMO UPS is pointless unless your running business critical or other critical stuff, and will only last a short while whilst you flick over to a permenant standby source (IE a backup generator) or wait until the power comes back on
Just sit out the power cuts which happen hardly ever, and go and roll a hoop down the street with a stick whilst you wait :p
I have an APC UPS and I only have the "essential" items attached to it - so PC, Display, Fibre Modem & Router.
Means in the event of a power outage I can safely save any work I've got open or safely log-out of any games I happen to be playing, even online etc.
Mine's a 700va unit and does it's job well. In an evening I can sometimes here the UPS kicking in as it watches for low current, brown-out's etc.
I have a UPS and Surge protector, comes in handy round my way which seems to suffer more than its fare share of power cuts! :(
Computer
Monitor
Router
External hard drive
Paper shredder
Printer
TV
DVD players x3
games consoles
Thanks
Whilst a £40 UPS won't be brilliant, it will afford you enough time to safely shut down your computer in the event of a power failure. The UPS should have some sort of interface to the computer so that it can be automated if you're not there.
You don't need any of the crap above plugged in to it though, just the computer and external hard drive (even a £40 UPS should run one of these for a few hours).
I've got one to help when we get the dreaded one second power blip which would sometimes knock the pc off. Also it's useful plugging everything into one UPS then having plugs everywhere.
cost about £85.
I got the same one around Christmas time for a little cheaper as it was on offer. I'm currently only using it for my home server (originally got it to use solely during RAID rebuilds but have left it connected). It's a good piece of kit, relatively cheap, seems to work great :) Lasts around 20 minutes according to the preview thingy.
