Photo of new 380X
560Ti from Colorful
http://www.eteknix.com/colorful-unleashes-igame-gtx-560ti-kudan/
The card packs a dual BIOS and a hefty 900MHz/4200MHz overclock which is raised to 1010MHz/4500MHz automatically when you install the extra power connector pack. In terms of accessory packs the first set is called the Air-Kit, which is assembled by five detachable heat pipes that draw heat from the main heatsink. The Air-Kit can be installed to the corresponding position that previously prepared on the graphics card, and can efficiently reduce the heat of the graphics card.
