Does not change the fact its rewarding failure with more money meaning that none of you can ever complain about apple fans or if Nvidia or amd screw up. Like I said that BBC documentary was right. You should watch it.
Companies like Nvidia and apple must be laughing. Op could have just turned a setting down and been fine.
:roll eyes:
A brief guide to flashing the bios would be the bees knees, my KAF2 980 should be with me tomorrow, then I will see which bios it has.
Yes, this is after the bios flash, would not go much above 10900 before, mostly 10800+Hey mate,
tempted to flash mine, did you get an increase in your 3D Mark after the BIOS flash? Also can you give me a brief guide on how to do this?Thanks.
I've clean reinstalled drivers last night as well. Cheers.
Seemed simple enough for me:
Downloaded above BIOS
Ran the "f" file.
Type in "Y" then "Y" again. Flashed for me no problem. Can confirm mine is sat nicely at 30% down from 52%.
Thanks to aachil for sourcing the BIOS![]()
Nice to see guys i havent done mine yet but i will later. Its interesting to see if any 3dmark scores have gone up
Did you go into device manager and disable the card first?
I'm investing in 970 SLi and am happy to drop settings.Turning down the settings a notch is a no go for me, if I've paid £640 for sli then yeah I'm gonna put up the settings to a reasonable level and not expect stuttering especially since it's only at a point once it goes beyond a certain memory threshold.
Could you give me an idea what kinda settings you find reasonable? Also, were you @ 1440p? Cheers!Is it the same flashing 1 gpu's bios as when you have 2 in sli? Or do you need to do things different?
What clocks are people getting and at what voltage?
Mines is topping out at 1520 with 1.25 volts.
