Software for reducing size of dashcam videos for Youtube
1 Apr 2014
Aberdeen
I've been thinking about making some of my dashcam videos suitable for Youtube. However, they're recorded in full HD @ 30 or 60 fps. (The dashcam is an 0801.) This means the file sizes for each segment are over 200 MB. Which software should I use to downscale them to a reasonable size and to extract the segments I actually want?
Freemake Video Convertor - http://www.freemake.com/downloads/
WARNING - it does come bundled with a lot of Rubbish you do not want to install. So make sure you read every screen and Decline everything. Some of the screens are a little awkward, hiding the text very small so be careful.
That's probably the easiest
THen you've also got:
HandBrake - https://handbrake.fr/
Can't remember if this has software bundled with it, but like any download, always play it safe and read everything it tries to install.
Windows movie maker will probably work, start a new file import the vid then chop it up. It's a free MS product.
Not exactly feature rich but you can export in various formats
