2 suggestions up there ^^^^
Cheers, I had a look through the post but must have missed them
I disagree with pretty much all of this.
There needs to be some appreciation for the anglicised versions of these dishes and understand that they're good in their own right. There's no 'should' with these dishes. They are what they are. A good minced beef chili can be an amazing dish, and is in no way inferior to a chunk/stew style chili. I think when you tell someone how a dish 'should' be made, because you think it's more authentic or whatever, you run the risk of becoming the amateur chef nerd who everyone rolls their eyes at. I've made chili both ways and I still go back to making mince chili, because that's what I crave sometimes and also because I think mince chili is better for toppings (ie nachos, potatoes, burgers, hotdogs).
Furthermore, properly browned minced meat can add a boat-load of flavour to a dish if you cook it properly. If you've ever tried Mario Batali's 'beyond brown' style of bolognese you'll know what I mean.
Re: the original topic. The biggest improvement I made with cooking chili was switching to a homemade chili powder (a good recipe, but I like to half the amount of garlic powder). It's really easy to do, and over the long run saves you time having to toast/soak/slice you different dried chilies individually each time. I've also tried using the tinned chipotles in adobo, and they're pretty nice, but expensive in the UK.
I also don't enjoy the addition of chocolate to a chili. I think when you put enough chocolate in so that you can taste it then you push the chili into molé territory in terms of taste, and I like chili more than molé.
Not arguing with your post in general DP but garlic powder is awesome - it's not a substitute for fresh garlic but it's a nice adjunct![]()
In much the same way as fresh/whole/ground/dried chillis. My house mate uses a mix of garlic powder, paste and fresh when he does his lasagne and it definitely makes a difference to the flavours. (It also keeps vampires and anyone with a sense of smell away for a day or 2)
Sounds tasty. My lasagne used to do the same but these days I try and reduce the amount of garlic I cook with (a little)![]()
The problem is it is hard to get good quality minced beef so it pretty much necessitates buying good chuck steak, taking out the meat grinder and dong it yourself and then cleaning up afterwards is just a hassle. Or you can just buy some good stewing beef, at the most a quick dicing is all that is required. That alone is reason enough just to make it with stewing beef.
Secondly you seem to completely miss the point where I clearly say that you can make good chili with ground beef it is just a different dish. You seem to be arguing this point from the opposite direction. If you want some spicy sloppy joe type mix to pour over the burger then that is fine if that is what you like but that is not the same as a good beef chili stew.
It is not about the Maillard reaction, in fact you don't have to bother frying the stewing beef at all. It is about the flavours that come out of a good cut of tougher meat, the collagen breaking down which thickens the sauce, the texture of of whole chunks of beef that shred in your mouth, and the flavour of the beef that is kept inside. A godo chili is like a good massuman curry, you get a rich spicy sauce but an unmistakable good beef taste as you you chew on the chunks of beef.
As for your suggestion to use a good chili powder, well that is surely better than a generic store bought tub of tasteless much but I fail to see how it can be an improvement over the traditional method. The whole point of using whole chilis and spices in general is because once they are ground up they loose their flavor rapidly, much like coffee the increased surface area rapidly increases the rate of oxidization. So the only way to make a good chili powder will be to make it fresh for each batch of chili you want to cook. Looking at the recipe you posted and the only step that is removed is the short soaking of dried chilis - the heating in a skillet and the grinding are still there. And garlic powder, really? There is just no need and there is no comparisons to fresh garlic. Skip the garlic powder and if you make that a recipe it will be very good I'm sure but it dont; see any significant time saving what so ever.
Also if you make a wet chili paste from soaking the chilis you can freeze the paste for a few months without an issue, unlike a dry powder left in your spice rack.
Are you honestly telling me there is no difference between pre-ground and whole spices?
Chilis like many other spices loose their aromatic compounds in time and this is greatly accelerated when grinding due to surface area. Chilies loose their aroma like many other spices but the capsicum remains for longer so you end up with heat but non of the flavors important for a chili con carne. Chili con carne is not about heat but complex broad flavors provided by many different types of flavorful chilies.
Anyway the difference between your ground chili powder recipe and traditional methods a mere 10 minutes soaking in water. If you believe that the powder won't deteriorate in storage then you can certainly believe that the paste from soaked chilis won't deteriorate when stored in a freezer. So there is really no difference in prep time worth worrying about.
Chili Verde, the basis is slow cooked pork with a variety of different green chilies with a crisper fresher zingy taste.
I haven't found a favorite recipe yet. As with a red chili it is important to have a variety if different chilies but you tend to use fresh chiliis instead of dried. A mix of Jalapeno, Poblano, Anaheim is easy enough to start with.
French Tart, i think im going to have a little go at that chilli you posted at the weekend.
only problem, ive got ancho chili and plenty of chipotle chili,
I dont have
pasilla,guajillos or chiles de arbol
What type or chilli are they taste wise? Ive got some habs, lemon drop and santa fe in the freezer from last years harvest. Suitable alternatives?![]()
I dont have
