I decided to a do a bit of benching of dirt showdown and Unigine Valley again last night but when running Unigine Valley (card clocks of 1240/1700) I started to smell a burning smell and smoke filling the room. Shut down the PC and looked inside only to find out that the modular pci-e cable and the Psu were solidly burnt together. This actually happened before and on both occasions I was overclocking to the max I could go on air putting +200v through the card (My Vapor-x 290 is volt limited so it will not go past that) and power limit of +50. . The other part of the cable which attaches to the card seems to be fine. I thought the first time it happened (6 months + ago) the cable might have not been pushed in right (made sure it was this time) and even though I have done various benches since at the same clocks it did it again.
My Psu is a Seasonic-X 850W (should be more than enough for one card even a 290 with a 3770K [email protected]) but it seems the cables are having a hard time when pushing my overclock to the limit. What I was wanting to know is if anyone has experienced the same thing and what their solution to it was? Using two cables might indeed work to spread the load between them so one does not get as hot but is there another solution?
Two of my Psu pci-e connectors are now unusable so I think I will try to rma the Seasonic and not overclock as much but I would like to know if this sort of situation can be avoided even when overclocking to the cards/systems max.
