"Kettle Lead" will always make a cracking noise when you plug it in, you wan't to worry when it doesn't.
Have you contacted OCUK? It will be under warranty obviously. Don't go messing with it in case it affects your warranty.
It's not great when it happens on a new PC, but they will have stress tested the machine before it went out however nothing is ever 100% certain.
Don't get wound up about it, give the guys a call on monday and I assume they will arrange to get the machine collected.
Goes into a shut down and restart loop.
If it comes on it functions normally, but it will only start up if i unplug the kettle lead and plug it back in.
The kettle lead makes a crackling sound when i plug it in also.
What to do?
