So I reviewed the ASUS Strix several months ago and I was very impressed with the build quality, cooling and Overclocking on the card. What was just as impressive was the efficiency of the card and how quickly ASUS got the card to market so soon after the 980 launch.
Onto Matrix then!! Lets first have a look at what is an exceptionally built card which has all the extra features you would expect from any card at this price point and some extras also.
The Matrix has a very well built cooler. It looks great is almost all metal with the distinctive ROG branding fitting in well with almost all builds and especially with ROG motherboards. The cooler is not only powerful but almost silent on Auto setting and still remaining quiet at full pelt. The back plate is done well adds rigidity to the PCB to prevent warping but is also working well at absorbing heat away from the card. At all times during my bench testing the GPU never exceeded 57C with most testing done around the 55C temp mark. This shows even more that the Cooler is not all show but real substance too.
Other features of the card are VGA hotwire to enable on the fly Voltage tuning with the ROG panel and also real time voltage monitoring with a digital multi meter.
We have dual bios. One for normal operation on Air and an LN2 bios unlocking even more options in GPU tweak to get the most out of the card on sub ambient cooling. No mods needed with this card plug and play goodness!!
All this having been said lets now see how well the card performs in practice. For the testing I will start off with stock volts gaming capable Overclocking and move onto LN2 in future posts.
Test ROG sorry rig!!
ASUS 980 Matrix
ASUS RVE
Intel 5960X 5625
GSKILL DDR4
Antec 1200 PSU
Win 7 sp1 64 Bit
Nvidia driver 344.48, 64 Bit.
Results
3D Mark 11 Performance
3D Mark Firestrike
3D Mark Firestrike Xtreme
Heaven 4.0 with Forum settings!!
Heaven Valley Xtreme HD settings
In these results we see on stock volts the core of this card doing 1515mhz Core Boost and 2040-2050mhz stable on mems. This was completely stable with no artifacts and running everything I threw at it easy. With more volts I am sure it can go higher but the purpose of this initial testing is to show what your average gamer can expect. This is not an outstanding result but above average for 980 and Overclocking is by no means guaranteed on any card. The cooler for sure has headroom for added volts with 57C at full OC being the best I have seen out of any cooler. What I also feel is important to mention is the out of box experience with the Matrix for guys not wanting to overclock at all. This is a 1405mhz!! overclock without the need to alter anything. Perfect for all gamers even at demanding settings and resolutions.
In conclusion I would recommend the Matrix for Air cooled performance. The build and aesthetics are top notch. The cooler is strong as 8Pack and whisper quiet. The factory overclock high with very good performance and for tweakers and overclockers the card has great features, software and headroom.
LN2 action to follow...............
ASUS 980 Matrix
ASUS RVE
Intel 5960X 5625
GSKILL DDR4
Antec 1200 PSU
Win 7 sp1 64 Bit
Results
3D Mark Firestrike
