Looking to buy a new laptop under £1000
19 Apr 2013
Hi guys I'm looking to get a new laptop, my budget is £1000 willing to go up to £1100 if the difference is massive. I'm not a looks person, I don't care if it all glows etc I just want the best bang for my buck... ATM -
the gigabyte P35W V2-CF4 looks like the best deal.
My question is, is there a better deal out there i'm not seeing? Also, would it be cheaper to pick up a custom built one without an OS as I have a Windows 7 disc, meaning that I don't really need it to come with an OS.
Also, is there anything new on the horizon that may cause a fluctuation in prices meaning if I waited a month id be able to buy a much better spec for the same price?
Many Thanks for all your help!
was looking at that P35W with the 870m best deal at the moment at £999.
Ended up going with the P34g as i wanted something a little smaller with the 14 inch screen and the GTX 860M is more than enough for me.
The p35w is very good i love the hot swappable drive. :D
You can get a 17" Asus G750JH ROG with 4GB 780M, 256gb SSD, 750GB HDD, Blu-Ray etc etc for under £1k if you look around.
It's a great machine for under a grand.
Also in the market for a new laptop for around £1000. Saw this one...reviews look pretty positive, only negative is poor reception/range of the WLAN.
Anybody else able to offer further thoughts/comments on this machine?
Thanks,
I have the 880m model which is identical apart from 880m and have never had any issues with the wireless. Tbh the Killer card used in this is miles better than the Intel one I had in my G751....
Been checking out reviews, performance stats etc and it appears to me that nothing can come close to the Asus G750JH in terms of bang for your buck (£970 incl VAT).
I can find very few laptops with the new GTX 965M (virtually identical performance to the GTX 780M)…the ones I have found have been circa £1200 and then don’t come with 16Gb RAM, Blu-ray, 256Gb SSD + 750Gb HDD.
It's a cracking machine for the money. It's also very well built with a nice alloy keyboard panel and white back lighting. The 751 feels cheap compared to the 750.
You also get a removable battery as well which is handy if it dies.
I doubt there is many of them left now so worth grabbing whilst you can.
I would much rather a 780M than 965M tbh.
Hi there
Deal done:
ASUS ROG G750JH-T4188H - 17.3" FHD LED / i7-4700HQ / NVIDIA GeForce GTX780M (4G DDR5) / 16G / 750GB + 256GB SSD / BD Read / Win 8.1 64B @ £959.99 inc VAT
Gorgeous gaming power
G750 is even slimmer and more gamer-centric than previous G Series notebooks, which is saying a lot. It meets your gaming needs as the ultimate weapon in any gameplay genre, making you a better gamer and a mightier ally to your teammates. Once more, the eye-catching design draws inspiration from stealth fighters, presenting an ergonomically-inclined surface for greater comfort during long gaming sessions. To better keep in touch with your co-op partners and everyone else, there's an HD camera, while a range of exclusive accessories complete your gaming experiences for more thrills at home and away.
Gaming-grade power
Enjoy desktop-level performance with a pumped 4th-generation Intel® Core™ i7-4700 processor and gaming-grade NVIDIA® GeForce® GTX 780M graphics, with ASUS TurboMaster technology for the ultimate gaming experience!
Everything you need for incredible gaming
Great gaming demands the fastest interfaces and the best displays, and G750 has been built to deliver nothing but the best. Its onboard Intel® Thunderbolt™ technology provides ultra-fast graphics and data transmission via a single connection, while the Killer Wireless-N 1202 chip delivers blazingly-fast and stable wireless networking. G750 supports next-generation 4K Ultra High Definition (4K/UDH) displays for incredible levels of detail, and with ASUS Trinity display technology you can connect up to three displays simultaneously for a truly incredible experience.
Spectacle of sound
Where many gaming notebooks treat sound as an afterthought, G750 puts it front and center. It features exclusive ASUS SonicMaster and ROG AudioWizard, designed by a dedicated team of audio engineers as a careful balance of hardware and software towards the best notebook sound. Sure, with G750 your games look their best, but they also sound fantastic. Every effect and note comes out with increased power, range, and clarity. This is more than enjoyment: as any gamer knows, sound is critical to success play, giving you the edge with sonic awareness and positioning. G750 integrates the latest design, with features specifically created for gaming and gamers.
Specification
- Display: 17.3" LED-backlit TFT LCD Display resolution: FHD 1920x1080 / 16:9
- Processor Type: Intel® Core™ i7-4700HQ Processor
- Processor Cores: 4
- Processor Clock Speed: up to 3.40GHz
- Hard Drive Supplied: 750GB *1
- Hard Drive Size: 750GB
- Solid State Drive: 256GB
- Hard Drive Speed: 7200RPM
- Memory Supplied: 16GB system memory
- Memory Size: 8GB *2
- Memory Type: DDR3L
- Memory Speed: 1866
- Memory Socket: 4
- Max. Memory Support: 32GB
- Operating System: Windows 8.1 (64 bit)
- Graphics Chipset: NVIDIA Geforce GTX780M 4GB (N14E-GS)
- Microphone:
- LAN: 10/100/1000 Mbps
- Wireless: 802.11bgn (Single band)
- Bluetooth: 4.0
- USB 3.0 Port(s): 4
- USB 2.0 Port(s): 0
- HDMI Port(s): 1
- VGA Port(s): 1
- Microphone Jack(s): 1
- Headphone Jack(s): 1
- LAN Port(s): 1
- Card Reader: SD, MMC
- Web Camera: HD web camera
- Keyboard: Illuminated Chiclet Keyboard
- Dimension: 41.0(W) x 31.8(D) x 1.80 ~ 5.00 (H) cm
- Product Weight (g): 4.00 KG (Without Battery) 4.50 KG (with 8 cell battery)
- Warranty: 2 Years
Only £959.99 inc VAT.
ORDER NOW
Stock due next Tuesday, might arrive Monday though! :)
