- 1 Mar 2004
- Warwickshire
For modern cars the recommendation is fairly simple: Use an oil which meets the manufacturers spec & grade & change in accordance with the service book.
What about an older car?
My Gt-Four for example - standard 90's DOHC 4 cylinder turbo, solid cam lifters, piston oil squirters, turbocharged.
Back in 1994 Toyota recommended anything from a 5w-30 to 10w-50 depending on some vague ambient temperature diagram, to an SL (or similar outdated - I forget) specification, and to change it every 5000km.
I somehow feel none of this is really relevant to a modern oil
If you want the maximum protection & longest drain intervals possible is it best to use the highest modern spec stuff you can get, which meets all the latest manufacturer longlife standards e.G Castrol Edge? Or will it be a needless expense, or indeed damaging for an older engine designed for obsolete additives?
What about the oil that every owners club seems to recommend by default with no apparent justification: Fuchs Titan Race Pro-S
Or will some cheap £20/5l Comma/Halfords fully synthetic do as much for an older engine as is possible?
