- 22 Apr 2014
See below the new Black Edition range from Plaxtor of there amasing PCI-E 2 x 2 M.2 Drives. The 512GB will be landing first and then the 128GB and 256GB versions are due in after that. Pricing has been confirmed and updated.
Plextor M6e-BK M.2 PCI-E 128GB Solid State Hard Drive Black Edition with Adaptor Card (PX-128M65e-BK-09) @ £129.99 inc VAT
The Plextor M6e Black Edition is a PCI Express solid state drive (SSD) specifically designed to create the perfect gaming platform that offers the extreme performance demanded by professional gaming.
Components of the highest standards are supplemented by the newly developed PlexTurbo 2.0 intelligent SSD software cache technology which achieves the final step in accelerated SSD performance.
Extreme Performance and Evolved Aesthetics
Toshiba's finest synchronous Toggle NAND flash memory, with the latest generation dual-core Marvell® 88SS9183 controller chip, are used to boost the sequential read/write speeds of the M6e to 770/625 MB/s. Random read/write speeds also broke through the 105K/100K IOPS barrier, giving the SSD the capability to easily handle the high data-exchange volume and complex computing demands of the most modern games to give gamers an unparalleled rush of speed and execution.
Additionally, Plextor has introduced high performance cooling fins to improve convectional cooling within the computer tower. In addition to their practical functions, the fins offer an awe-inspiring exterior to fully sate the owner's desires.
Technbological Revolution - Gamers Choice
PlexTurbo 2.0
PlexTurbo 2.0 is the latest generation of SSD memory cache solutions offered by Plextor. Version 2.0 comes with increased system memory size, boosting the service life of M6e Black Edition SSD while vastly accelerating access speed performance.
True Speed
Plextor True Speed Technology keeps long-term SSD performance at like-new speeds after periods of use and when the SSD is nearly full.
True Protect
Plextor's exclusive TrueProtect system provides both 256-bit AES full-drive encryption and advanced multi-layer error checking for full data protection.
Intelligent PlexTurbo 2.0 Caching
PlexTurbo 2.0 offers an intelligent SSD memory cache solution. Plextor M6e Black Edition is able to use system memory for boosting storage and access performance, liberating it from the speed limits imposed by hardware interfaces.
Performance Boost
PlexTurbo 2.0 includes an Intelligent Boost Engine® (IBE) technology, to automatically detect hot data (frequently accessed) and cold data (occasionally accessed) and applies the best caching patterns for higher performance.
With Reduced Memory Usage® (RMU) technology, PlexTurbo 2.0 will dynamically create and compare data patterns then merge the same command data into one buffer to accelerate write response speed.
Safe Power Loss
Automatically protects against loss of data from the RAM cache during a power interruption or unexpected system crash.
Life Extension Mechanism
Extends life of SSD flash memory by using smart algorithms to eliminate unnecessary writes.
Perfect Compatibility - Plug and Play
The M6e Black Edition supports both UEFI and legacy BIOS booting, providing flexibility and compatibility with a wide range of systems. Full UEFI support allows the system to initiate all storage devices simultaneously, improving efficiency and cutting boot times by half.
Designed for PCI Express
The M6e Black Edition uses the ultra-modern PCI Express connection to achieve new performance records. It provides higher performance and bandwidth than conventional SATA connections
Advanced next-generation form factors supported, the M6e Black Edition can help gamers easily build extreme-performance gaming computers. Utilizing a PCI Express Gen 2 x 2, the M6e Black Edition bypasses the SATA speed bottleneck to improve the gaming experience.
Support AHCI Mode
Driver-free AHCI (Advanced Host Controller Interface) compatibility eliminates the need for additional drivers.
Plextor Quality and Reliability
Plextor's Zero-Failure Zero-Error standard during rigorous testing using the world's most advanced SSD testing facilities - FLEXSTAR testing chamber. The M6e Black Edition provides extreme reliability with a MTBF calculated at 2.4 million hours after reaching.
Full Five-Year Warranty
The M6e Black Edition is backed by a full five-year Plextor warranty with the reassurance of a network of repair centers and international technical support. An extensive technical support system will provide support throughout the drive's long life and make the M6e Black Edition a performance upgrade that you can have total confidence in.
Specification:
We recommend Windows 8 or above as an operating system for use with these M.2 PCIe SSD's
Only £129.99 inc VAT.
ORDER NOW
Plextor M6e-BK M.2 PCI-E 256GB Solid State Hard Drive Black Edition with Adaptor Card (PX-256M6e-BK-09) @ £209.99 inc VAT
Specification:
Only £209.99 inc VAT.
ORDER NOW
Plextor M6e-BK M.2 PCI-E 512GB Solid State Hard Drive Black Edition with Adaptor Card (PX-512M6e-BK-09) @ £409.98 inc VAT
Specification:
Only £409.98 inc VAT.
ORDER NOW
PlexTurbo 2.0
True Speed
True Protect
Performance Boost
Safe Power Loss
Support AHCI Mode
- 48hr Sustained Read and Write Test - Two days continuous 4K file read / write test, zero error pass requirement.
- 4000 Times Idle Test–Sleep and Hibernation Test - After 24 hrs read & write SSD enters sleep (S3) mode and is woken after 5 minutes, repeated for hibernation (S4) mode, zero error pass requirement.
- 250 Times Power Cycle–Cold and Warm Boot Tests - Continuous cold boot and warm boot cycles 250 times, zero error pass requirement.
Specification:
- Interface: M2/PCI-E, exceeds SATA3 limitations with upto 1.5x performance boost.
- Duo BIOS Support: Set as boot device under UEFI BIOS or the legacy BIOS
- Compatibility: AHCI Support, no drivers needed.
- DRAM Cache: 256MB DDR3
- Read Speed: 770MB/s
- Write Speed: 335MB/s
- Read IOPS: 96,000
- Write IOPS: 83,000
- Controller: Server Grade Marvell PCI-e Control Chip (88SS9183)
- Warranty: 5 Years
ORDER NOW
Specification:
- DRAM Cache: 512MB DDR3
- Write Speed: 580MB/s
- Read IOPS: 105,000
- Write IOPS: 100,000
- Warranty: 5 Years
ORDER NOW
Specification:
- DRAM Cache: 1024MB DDR3
- Write Speed: 625MB/s
- Warranty: 5 Years
ORDER NOW
