I've got my filters fitted now, they look great behind the fascia, you'd never know they were there. The mesh is incredibly fine so I am sure they'll stop most of the dust. The airflow does seem to be a little more restricted, but there's no difference in temps. Thanks for the tip Cooper.
Aardvark - any luck with cancelling your Demciflex order?
That's a shame, but from what I've read you can't beat Demciflex so I am sure it will perform very well.
That's some pretty swift postage. Glad it looks good. You may find it needs cleaning frequently, at least that's what I've found with the new ones I have. It certainly beats cleaning the inside of the case often though![]()
