Personally with a £500 budget I'd have gone for the HD650 + Schiit Modi 2 Uber + Schiit Vali but that's just me and we may well have different tastes.
that's very poor show from the Z1 my nexus 5 stomps the older X1's as well as my amp does.
Are you ticking the SPDIF out box and selecting PCM in the Xonar CP?
Yeah sorry I thought mine didn't contain any accessories only to find they were nicely concealed. I got mine from rainforest. On the other hand this concerns me:
I'll have to charge it first before I give it a spin and make any judgements from there.
Oh wow thank you! Is it recommended to play it out the optical from the soundcard or the computers USB? Sound card has more interference right?
Anyways the sound quality jumped further in terms of quality when paired with the Schiit M&M stack. Background noise has been virtually eliminated, the soundstage got even better and treble got brighter. Loving it![]()
Those are simplified Chinese, so it is definitely from mainland China, rather than Hong Kong or Taiwan (which they use traditional Chinese).Those seems Chinese to me...LOL you went to Hong Kong?
Ive got the 600's along with 598 and 700's . Personally I thing the 598 are better at picking out instruments than the 600's
ahh mate can you tell me the difference between the 598s and the 650s? i hear the 598 is amazing but not much of a difference between the 650, apparently the 598 sounds a bit more bass minus some mid range sound stage?
I can get the 598s for 129 and the 650s for 225, so is there 101 pounds of sound difference? like is it noticeable?, I run all my head phones from my ZX sound card and the 3.5mm jack on my logitech Z2300 2.1s (i must admit that its much more louder thru the logitech speakers than the ZX)
I wont get a headphone amp as i dont need it.
If you are using the output from the Logitechs then there is absolutely no point in getting good headphones because you won't hear the benefit. Good headphones will only shine when you allow them to and that means feeding them with high quality, clean audio and you're not going to get that from an afterthought on a speaker system. The headphone out may be louder from the Z2300s but the quality will be higher from the Zx.
At least you're using the Zx DAC, which isn't bad. I would expect the Zx headphone amp to sound better than the headphone output on the speakers, unless it's just a pass through.
